Holden 6 Goss mechanical fuel pump pin caps falling out.
3 replies to this topic
#1 LJGTR6
LJGTR6
  • 309 posts
  • Name:Steve
  • Car:1977 LX SL 4 Door and 1973 LJ 2 Door
Posted 20 January 2013 - 12:27 PM
A little while back i found some oil under the car and tracked it back to the
fuel pump and this small brass cap had fallen out.
Thinking it was just a faulty pump I bought a new one for about 100 dollars and just replaced it.
The new one has done the same thing within about a year.
Has anyone else had this problem??
The engine like is a bit of a shaker at idle because of the cam.
I am not sure if it is this doing it or they are just cheap shitty pumps.
either way i will try and repair this some how.
I am not sure if the loctite they are using is strong enough or
maybe not oil resistant.
Attached File  photo (2).JPG   139.44K   6 downloads
#2 LJGTR6
LJGTR6
  • 309 posts
  • Name:Steve
Posted 22 January 2013 - 07:35 PM
I think this will do the job.
8mm bottoming tap in each side to get about 4 threads.
Then loctite in each side an 8mm grub screw.
holds the pin in place as well. Stops it from rotating and walking sideways.
Attached File  photo (3).JPG   136.48K   7 downloads
#3 _Bomber Watson_
Posted 22 January 2013 - 07:58 PM
Nice mod.
#4 N/A-PWR
  • 9,639 posts
Posted 01 January 2015 - 04:59 PM
Nice Mod indeed Steve,
+2
Nice mod.
One Like Button for you too
