Posted 02 February 2013 - 04:47 PM
Picture 1.png 91.27K 97 downloads
Note: must be 4 speed without all the gear linkages on the end.
Ta
Marty
#2 _woosha_
Posted 03 February 2013 - 08:57 AM
Cheers woosha
Posted 04 February 2013 - 11:54 PM
I'm still confused.....this diagram still shows the shift control tube. Why? Do all columns have the control tube?
My diagram shows no tube but is a crappy pic which doesn't make it easy to assemble.
Anyone else have a diagram preferable with the parts layed out?
steering column.jpg 45.76K 172 downloads
Thanks again
Marty
Edited by sibhs, 04 February 2013 - 11:57 PM.
Posted 05 February 2013 - 12:54 AM
The pic Woosha posted is from the LC workshop manual. Seems they just cheated a little with the drawings and modified a column shift drawing for the floor shift type. The steering columns to suit with floor shift don't have the gear change tube and the lower shaft bearing is different.
Best to work from the pic you have from the LJ parts book. It appears that GMH didn't see a need to draw up detailed exploded views of all the column parts and how they go together. I've never been able to find any diagrams that are more detailed than what you already have when it comes to the complete steering column.
Are you planning on using an original type nylon lower shaft bearing or doing a conversion to a ball race bearing?
Dave.
Posted 05 February 2013 - 09:44 AM
Yeah Woosha mentioned it was from an LC manual.
I'm open to suggestions on which is better/easier, bearing or bush. On mine the area the lower bush sits has cut outs for the gear linkages, I presume they aren't on the 4 speed model. I might have to weld a wrap of metal around the bottom?
Really like my cars to look original as possible.
Does anyone have a pic of this bearing/bush section?
Marty
Posted 05 February 2013 - 04:00 PM
Anyway, have read of this to start with.
http://www.gmh-toran...r-bearing-size/
Posted 11 February 2013 - 09:11 AM
Thanks Dave, good info and great pic's of the bush in there.You could cut the bottom end piece off a 4cyl column jacket (if you can find one) and graft it onto your 6 cyl column
I have stumbled on a damaged manual housing which I plan to cut the lower section off and weld onto mine. Then machine or smooth out my lower shaft section, (pitted) and make up a bush to suit while still using the original retaining clip.
Apart from less holes in the floor shift tube, it's actually shorter aswell.
IMG_2139.jpg 48.87K 14 downloads
#8 _Skapinad_
Posted 11 February 2013 - 02:35 PM
Also tagged with one or more of these keywords: Wanted, LJ, 4 speed
Holden Tech →
Brakes, Wheels and Tyres →
LJ Standard disc Brake ImprovementsStarted by salamiman , 05 Dec 2023 LJ, Brakes, LC, Disc |
Holden Tech →
Wheels for LJ with HQ brakesStarted by Beddy , 18 May 2022 lj, hq brakes, wheels lj, offset and 2 more... |
Holden Tech →
Driveline →
4 speed to TrimaticStarted by SLR74 , 13 May 2021 Trimatic, auto, 4 speed, manual |
Holden Tech →
General HB-LC-TA-LJ →
New Torana for the collection #barnfind - Tag IDStarted by _Aimz82_ , 12 Aug 2019 LJ |
Holden Tech →
Help with my 72 GTR pleaseStarted by _eddoGTR72_ , 21 May 2019 I.D, GTR, LJ |
