308 Heads
_Barman_
Posted 18 June 2006 - 07:28 PM
I didnt believe him but it was cheap, so now that ive got it stripped these heads have monster valves and double springs (compared to my spare 308 heads)
So is there any way to know if they are or not ? (do they stamp them anywhere)
thanks Baz
_[BOTTLEDUP]_
Posted 19 June 2006 - 09:23 PM
Tho Yella Terra heads run Yella Terra valves, if they were purchased complete. They'll have YT stamped in the valve face.
Posted 19 June 2006 - 09:35 PM
_Yella SLuR_
Posted 20 June 2006 - 03:35 PM
God, feel like I've posted this 1,000 times now. Think it must be on the old site. This is all from a 308 perspective by the way, not sure about variants on the six heads.
Early Y/T heads have no identification at all on them, were painted Holden Rocket Red, Holden still cast into them, no Y/T on the valve faces. I don't believe they came in Yellow till the 80's, except for the adverts. The only way to identify the early ones are much larger valves, nearly double standard, modified combustion chamber to take the bigger valves (valves about 50% bigger than the L34 valves even), and the valves have the black tuft-riding on them. The inlets have minimal machining, but you'll find that there is no sharp casting edge in the inlets/outlets.
A set of early 308 Yella Terra's with hardened exhaust valve seats.
Later Y/T heads actually had the valves with Y/T cast into the face.
Posted 20 June 2006 - 09:21 PM
I beg to differ....... Yella Terra have never fitted a bigger than 1.94/1.50 or L34 size valve combo to a cast iron 308 head, the valve spacing wont allow it. When they made their own alloy heads they fitted 2.02 intakes but had to spread the spacing to do it.
_Yella SLuR_
Posted 20 June 2006 - 10:29 PM
I thought these valves where huge, then the dude that did the heads showed me some GT351 heads......make these heads look tiny in every respect.
Edited by Yella SLuR, 20 June 2006 - 10:31 PM.
_Barman_
Posted 21 June 2006 - 08:00 PM
Ive got yt heads thanks Baz
