How do you remove fan motor bolts?
LJ LC
11 replies to this topic
#1 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 15 February 2013 - 09:37 PM
I can't work this out. :mellow:
Need to remove these little spiked clips to get the bolts out! These are in the heater box and go through the fan motor.
How is it done with-out destroying the clips? I tried levering with a micro screwdriver, I could try harder, just hoping for an easy way out.
Marty
Attached File  photo.JPG   122.2K   5 downloads
#2 S pack
  • 15,691 posts
Posted 15 February 2013 - 10:18 PM
From memory I ended up using a small screwdriver to carefully bend the lugs out enough to get them off.
#3 Beans
Beans
  • 26 posts
  • Name:Geoff
  • Car:72 LJ XU-1, HQ GTS Coupe
Posted 16 February 2013 - 01:06 AM
Yeah what Dave said. Go slow with a small screwdriver.
If you bust then teeth from the lock washer and need a replacements you may be able to get some the correct size from Small Parts and Bearings in QLD.
http://www.smallpart...ringsteel/all/1
#4 _LONA-CK_
_LONA-CK_
Posted 16 February 2013 - 05:59 AM
i use a pointy nose pliers and a small flat blade, buy squeezing the metal outside ring with the rubber under it, bit buy bit and then turn it as you work it.
i know there are a lot of ITS going on there hay.
good luck cheers gong
#5 _Agent 34_
_Agent 34_
Posted 16 February 2013 - 06:31 AM
you can just leave them in the metal platers will go right over it.
the rubber is not effected by the acids and zinc
that's how i did mine.
turned out fine
yep it's a bugger of a job
Edited by Agent 34, 16 February 2013 - 06:32 AM.
#6 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 16 February 2013 - 09:35 AM
Thanks guys will give these ideas a go.
The metal base is totally rusted so I've bought a new heater box and need to transfer this stuff over.
Marty
#7 Beans
Beans
  • 26 posts
  • Name:Geoff
Posted 16 February 2013 - 09:58 AM
Ooops !
Sorry I provided the wrong link for replacement retaining rings.
This is the correct one.
http://www.smallpart...ngsbasic/all/1/
#8 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 16 February 2013 - 12:44 PM
That was challenging.....
Heres how I did it.
It required 2 pairs of hands, long nose pliers, very small flat blade screwdriver and a hammer.
I cut the section out and mounted in a vice.
Squeeze down on the grip washer and insert screwdriver above spike then lightly tap with hammer until you can lever the spike over the ridge. While still keeping pressure on this spike so it doesn't drop back in the groove do the same to the opposite side and so on.
It was tricky and even another a third pair of hands could be handy.
Attached File  photo.JPG   131.71K   4 downloads
Attached File  photo1.JPG   116.76K   4 downloads
#9 _LONA-CK_
_LONA-CK_
Posted 17 February 2013 - 08:58 AM
well it would make you wonder how i do it with one hand then ay marty???
cheers gong
#10 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 February 2013 - 04:29 PM
We all know your a genius when it comes to working on Torana's, Gong.
Just did the second one then with my wife's extra hands.
Thanks for your help.
#11 _LONA-CK_
_LONA-CK_
Posted 17 February 2013 - 05:57 PM
i use vice grips when i need to do them.
cheers gong
#12 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 18 February 2013 - 09:29 AM
Like I said......GENIUS
Also tagged with one or more of these keywords: LJ LC
