Turbo 202 UC Torana
24 replies to this topic
#1 _rb3torana_
_rb3torana_
Posted 19 February 2013 - 06:50 PM
Thought I'd post some pics and specs on the UC.
Specs are: 202 blue motor 40" block, blue rods, duralite pistons, 8.4:1 comp, camtech 238/248 solid cam, stock blue head with camtech springs, yella terra rockers, aussiespeed manifold, 650hp holley, custom turbo manifold, 50mm wastegate, garrett gt3582r turbo.
Saginaw 4spd with NPC clutch, stock open 3.08 ratio diff.
With this setup it ran a best of 13.0@113mph at 15psi, its now got a full manual trimatic with a 4500rpm convertor shop converter, I took the head off and gave it a mild port and opened up the chambers also dropping the comp to 7.8:1. Also added water injection and 20psi boost.
It recently blew a head gasket and bent a rod...........
Which is where its at now, getting some unleaded pistons and another set of blue rods with arp bolts.
Lots of pics
Edited by rb3torana, 19 February 2013 - 06:53 PM.
#2 _rb3torana_
_rb3torana_
Posted 19 February 2013 - 06:56 PM
Just some youtube vids.
http://www.youtube.c...h?v=vjN_I_aLJoc
http://www.youtube.c...h?v=8MLzQNxwvsM
#3 _mick74lh_
_mick74lh_
Posted 19 February 2013 - 07:14 PM
That is awesome. Nice sweet sounding engine with the turbo.
#4 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 19 February 2013 - 07:25 PM
thats awesome, can i send you my uc for the same treatment??
#5 _Growler_
_Growler_
Posted 19 February 2013 - 07:31 PM
Very very soopa cool sleeper man awesome job!
#6 _stretchlc_
_stretchlc_
Posted 19 February 2013 - 08:11 PM
I really like this car...Good Job dude...theres plenty more in that car.....if the diff holds up that is
#7 _TorYoda_
_TorYoda_
Posted 19 February 2013 - 08:46 PM
I have run 11 second ET's in the 120Mph + zone in an LX sedan using a banjo and the fine spline axles, so I wouldn't be too worried about the diff just yet.
#8 _rb3torana_
_rb3torana_
Posted 20 February 2013 - 07:17 AM
Was that with an open centre? Thanks for the comments :D .
#9 _stretchlc_
_stretchlc_
Posted 20 February 2013 - 11:48 AM
Famous last words!!..hahaha
#10 _Torrie_Man_
_Torrie_Man_
Posted 20 February 2013 - 06:09 PM
Wow that a really neat setup too!
#11 _rb3torana_
_rb3torana_
Posted 24 February 2013 - 06:27 PM
Well all back together now, lag seems the same even with the 6.8:1 compression. I also checked the TDC mark on the balancer and it was out 4 degrees so really when I had 28 degrees with the water injection on I only had 24 degrees. Its now got a real 24 degrees and 20psi with no water injection and no ping. Air fuels in the mid 11's. It feels the same as when the water injection was on though..... :) Also noticed the spark plugs had some very light black pepper on them, I had bp6ef plugs in it and put some br6ef's in it and there was less pepper, probably as its acted a little retarded and cooler, might try some 7's.Hopefully to the track soon.
Edited by rb3torana, 24 February 2013 - 06:35 PM.
#12 Heath
  • 18,393 posts
Posted 25 February 2013 - 07:25 AM
Awesome car! Very interested in seeing how it progresses
#13 TerrA LX
Posted 25 February 2013 - 07:40 AM
Love it when a UC comes together.
#14 _Matvex_
_Matvex_
Posted 25 February 2013 - 09:08 AM
Your engine bay looks really tidy and balanced! The stealth pipes with the black engine bay looks really cool.
#15 _rb3torana_
_rb3torana_
Posted 05 March 2013 - 10:25 AM
Testing the converter on the primaries and footbrake.
http://www.youtube.c...h?v=arS0RAEWwjo
#16 _Bomber Watson_
Posted 05 March 2013 - 06:58 PM
That sounds nutso, love it.
#17 _rb3torana_
_rb3torana_
Posted 25 April 2013 - 10:54 AM
Since my last post I got abit of crap in the 1mm oil feed and stuffed the rear bearing in the gt35 so I got a ebay gt45.
Took it to the track last night, ran [email protected]. Couldnt build any boost on the brake so pretty lazy till 2nd gear :lol: . 30psi 25degrees timing on straight pump 98 (no water/meth). Still the 186 with 202 dished pistons, 6.1:1 compression. Ebay gt45. Still no msd lol.
 Need to chop the exhaust manifold up and weld a t4 flange to it. At the moment its got a very restrictive t3 to t4 flange as I had to mount the turbo offset to the manifold, so the exhaust gases are hitting the turbine at a 45 degree angle lol. Its probably alot why even when it builds boost its still lazy (no funnel effect). Cheers
#18 _jabba_
_jabba_
Posted 25 April 2013 - 11:59 AM
Is there anything you can do about the mixtures? It seems really rich at idle and off boost then it leans out then richens up again... At one point there it was like 14:1 on boost :S. Have you thought of going throttle body injection for a simple upgrade? Megasquirt 3's are cheap and have launch control so you can build as much boost as you want ;). What are you doing about ignition control? Thats a shittt load of boost :D.
Edited by jabba, 25 April 2013 - 12:02 PM.
#19 _rb3torana_
_rb3torana_
Posted 25 April 2013 - 12:29 PM
It must have been the cool air last night, it usually go straight to 11.5:1 and sits there, usually its around 28-29psi, so maybe the extra 2psi leaned it out abit (as well as cool air). Its got 36deg timing until 8psi then back to 25deg from then on.
#20 _jabba_
_jabba_
Posted 25 April 2013 - 01:30 PM
damn, thats a lot of timing :). well done.
#21 _stretchlc_
_stretchlc_
Posted 25 April 2013 - 01:48 PM
123.5 mph is high 10 second 1/4 mile territory.........yikes.............get the "doughyness" taken out of it off the rotary muffler and this thing will haul A$$.
#22 _jabba_
_jabba_
Posted 25 April 2013 - 08:13 PM
Maybe it just needs a shot of nawwwssss until it comes on boost?
#23 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 26 April 2013 - 08:18 AM
The mixtures really need to be attended too, some scary numbers when it's on boost & pig rich in the lower revs, as jabba has already pointed out.
#24 _rb3torana_
_rb3torana_
Posted 26 April 2013 - 02:19 PM
It needs to be that rich at idle with a 16thou plug gap otherwise its stall and pops up the intake contantly, yeah dont worry I didnt like how lean it was yet got richer by the end of the track, 11.5 is where it usually sits on boost.
#25 _jabba_
_jabba_
Posted 26 April 2013 - 05:09 PM
Ill megasquirt it for you mate, im going up to qld next month ;) ;) ;).  Doooo ett ;).
Edited by jabba, 26 April 2013 - 05:10 PM.
