Opening an Oil Filter - any tips?
19 replies to this topic
#1 _jklumpp_
_jklumpp_
Posted 07 May 2013 - 06:05 PM
I want to cut open my oil filter to inspect the contents - does anyone have any suggestions of a good way to do this?
I had thought that one of those side opening can openers would do the trick, but it doesn't fit on...
Other than hacking into it with a screw driver & tin snips, is there an easier way?
#2 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 07 May 2013 - 06:17 PM
Buy one of these.
http://02e449d.netso...ltercutter.aspx
#3 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 May 2013 - 06:21 PM
#4 Indy Orange
Indy Orange
  • 2,903 posts
  • Name:Paul
Or try grinding around the outer edge.
#5 _Bomber Watson_
Posted 07 May 2013 - 06:27 PM
Using a grinder puts metal filings in it....
I have an opener similar to the one Craig linked, just a cheap summit one, difficult to use but it works, i think a better one would be easyer to use but meh.
#6 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 07 May 2013 - 06:35 PM
Or you could just trim the seam completely off with a decent pair of tinsnips.
#7 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 07 May 2013 - 06:43 PM
Do you know anyone who works at a Hastings Deering or similar place, they cut oil filters to check for contaminants, maybe ask if you could borrow theirs for an hour or 2.
#8 _Gunmetal LH_
_Gunmetal LH_
Posted 07 May 2013 - 08:27 PM
#9 TerrA LX
Posted 08 May 2013 - 02:22 PM
Looks like an oversized pipe cutter.
#10 _JChantrey_
_JChantrey_
Posted 08 May 2013 - 02:52 PM
hacksaw
#11 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 08 May 2013 - 09:04 PM
hacksaw
you are kidding right?
#12 rodomo
  • 18,028 posts
Posted 08 May 2013 - 09:52 PM
plasma cutter...................no filings? :tomaatit:
#13 _Bomber Watson_
Posted 08 May 2013 - 10:07 PM
Bet he has a lot of metal in his filters when he opens them......
#14 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 09 May 2013 - 01:03 PM
s
#15 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 09 May 2013 - 03:02 PM
I have one of the Summit ones as well, a bit painful but does the job.
#16 _jklumpp_
_jklumpp_
Posted 18 May 2013 - 09:53 PM
because I needed it 'now', I decided to make one....
First attempt failed, as I found I had the cutter too low, and it was up against the solid base..... A few modification to raise the cutter, and it worked a treat!
....PS, for anyone thinking about doing this themselves - if you can wait for delivery, just spend the $60-70 on one of the longacre or summit ones!
#17 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 19 May 2013 - 07:53 AM
Good on you for having a go !
What did you use for a cutting disc ? Can opener ?
#18 Rob2408
Rob2408
  • 309 posts
  • Name:Rob
  • Car:1974 L32 SLR
Posted 19 May 2013 - 08:48 AM
OK, so what did you find?
#19 _jklumpp_
_jklumpp_
Posted 19 May 2013 - 10:49 PM
Yeah, $2 can opener for the cutting disk.
What I found was lot's of silver glitter.... but that was a foregone conclusion, as I ended up pulling the engine out before I finished the cutter.
Will use it every service now to keep an eye on things...
#20 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 19 May 2013 - 11:38 PM
yours is way cooler than the summit job
