Wrong Windscreen locking strips from Rare spares, again.
23 replies to this topic
#1 The German
The German
  • 268 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 20 May 2013 - 03:37 AM
Dear Torana friends,
did someone order Torana LH windscreen locking strips and corner clips and did get the right ones?
2011 i ordered locking strips and corners for my Torana to Germany.
The locking strip corners didnt fit for the front and rear. ( They looked like not deep enough for the strip and also two of the front ones should have a more open angle than 90 degrees)
I did contact Rare Spares and they told me about the known problem and said that the corners are wrong manufactured.(For the thicker than original locking strip)
Last month i was in Melbourne and bought me a new locking strip set from Rare spares.
At home i found out that the windscreen kit has still the thicker locking strip. But the locking strip corners are made now for the thicker strip.
The bad thing is that two of the four corners have still the wrong angle.
The angle has to be more open than 90 degrees.
For the rear its the same problem.
Is there nobody testing the parts before going over the counter ?
Did someone get the right ones ?
Uwe
#2 The German
The German
  • 268 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 20 May 2013 - 08:54 PM
Edited by The German, 20 May 2013 - 08:59 PM.
#3 eyepeeler
eyepeeler
  • 1,959 posts
Posted 20 May 2013 - 08:59 PM
Those 2 are nothing like what you need!! Would be more than disappointing.
Like your car by the way......
#4 unclefestal34s
unclefestal34s
  • 1,123 posts
Posted 20 May 2013 - 09:32 PM
those corners are a rubbish fit,and are incorrect for lh lx uc models plus there very soft,..i still use the original ones all the time..also i've been fortunate with my windscreen background to have a rolls of the original mylar chrome moulding
#5 _sting_
_sting_
Posted 20 June 2013 - 10:45 AM
its about time they pull there head out off there ass and stop and think why are we having all these problems how many times do they get it wrong, the more i hear about these guys i shake my head , but on that note at least they are trying, all i can say is go back to the start and look at who is giving the go ahead to produce these parts and give them a kick up the ass . I have spent thousands off dollars on your gear but im getting tiered off returning stuff .
cheers sting
#6 S pack
  • 15,708 posts
Posted 20 June 2013 - 01:42 PM
1st and most important thing that needs to be done is make the correct Mylar insert to suit LH/LX/UC instead of flogging a generic Mylar that is sort of close enough.
As you can see in Uwe's pic the Mylar insert (which looks more like the LC/LJ Mylar) isn't even close to matching the original LH/LX/UC escutcheons.
#7 hanra
  • 10,954 posts
Posted 20 June 2013 - 01:56 PM
I did have a leftover length of NOS Mylar (not sure if I threw it out now). I offered it to RSP some time ago but I believe I was advised they had the situation under control. I also have some spare genuine windscreen corner pieces I can supply them. No use to me.
#8 _Lazarus_
_Lazarus_
Posted 20 June 2013 - 02:14 PM
 I bought my UC with no windscreen so I bought a length of locking strip and a set of new corner pieces. The original corner pieces turned up while looking through the bits and pieces which came with the car but does this mean this they will not fit the new locking strip I have bought and I will have to use the bodgy ones... ?
I might give it all to Windscreen O'Briens to sort out if that is the case.
You would think that Rare Spares could do better.
#9 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 20 June 2013 - 02:24 PM
Brad i'd be keen on getting hold of your corner pieces.
#10 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 20 June 2013 - 02:47 PM
#11 S pack
  • 15,708 posts
Posted 20 June 2013 - 02:49 PM
Sit your original UC escutcheons over the end of the Mylar insert you bought and see how well they match.
I for one would be interested to see a pic of the result.
#12 S pack
  • 15,708 posts
Posted 20 June 2013 - 03:00 PM
Just had a look at the Mylar profiles that Rares sell. Looks like they supply only one profile (K540) to suit HB through to UC Torana. The profile is clearly only suitable for HB through to TA Torana.
 http://www.rsp.net.a...spx?rpgid=IPE14
#13 _Agent 34_
_Agent 34_
Posted 20 June 2013 - 06:37 PM
ERRR
but the LC - LJ  windscreen rubber seems to really not accept the bead locking strip and the cover, the joiner seems to not sit flush in the rubber with the locking strip engaged.
I have evidence and when i tried to settle it back down it popped out ?
#14 _Bomber Watson_
Posted 20 June 2013 - 08:14 PM
Is it just me, or do those corner locking things look like HB-TA items???
#15 S pack
  • 15,708 posts
Posted 21 June 2013 - 12:51 AM
Agree DJ, the corner escutcheon that is 90 degrees looks like the LC/LJ type but the one that is an acute angle wouldn't suit.
I'll take a punt and say they wouldn't fit 100% with genuine/original HB - TA Mylar insert though, only the generic Mylar.
#16 _Skapinad_
_Skapinad_
Posted 21 June 2013 - 05:28 PM
Need dentures.
#17 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 21 June 2013 - 07:06 PM
the replacement was the same, i haven't bothered sending it back
#18 _Lazarus_
_Lazarus_
Posted 21 June 2013 - 09:12 PM
I'll open the package and have a look tomorrow. It's probably about time I workrd out how to post pics too.
#19 hanra
  • 10,954 posts
Posted 21 June 2013 - 10:01 PM
I knew I made a post about this a while back.
Just got my NOS Mylar locking strip from WA!!! Yeah pretty big difference between the Rare Spares stuff and this...
See for yourself.
NOS on LHS:
NOS on bottom:
#20 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 23 June 2013 - 11:15 AM
let me know what you want for them big guy?
#21 hanra
  • 10,954 posts
Posted 23 June 2013 - 11:41 AM
They are old and shitty. I'd think they would be good for RSP to use and destroy them to make suitable repros.
#22 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 23 June 2013 - 12:15 PM
ok ta
#23 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 23 June 2013 - 12:43 PM
That would be good for everyone Brad.
#24 The German
The German
  • 268 posts
  • Name:Uwe
  • Car:LH V8 1974
Posted 21 July 2013 - 11:02 PM
.....any idea where i can get the right set of Mylar and corners front and rear?
Uwe
