SBC pitting in bore - Is it stuffed?
16 replies to this topic
#1 TempesT
TempesT
  • 493 posts
  • Name:James - JImmy or Jim
  • Car:LX hatch
Posted 26 May 2013 - 01:01 PM
So I haven't been around here much of late as I have been playing with the 4x4 and my guns.
Today I decided to pull the wrapping off my 400 sbc block to clean and re lube the bores.
Anyway it turns out I didn’t wrap it so good when I was in Mackay and she had some surface rust in one of the bores. :sad:   I gave the offending area a quick emery and wd40 rub and the area had pitted the bore.  :furious:
The block is 0.04 over already and I was just going to have it honed and decked before I decide to build it.
These photos are from the top of the bore looking down at the pitting. Im not even sure it would be within the piston rings travel stroke.
02d6f5ec-5ca5-4595-aa82-a0a257caf832_zps
3d0dc632-0248-4472-ad35-aedd21f3bc74_zps
So how bad it is? Would it clean up with a hone? Have I frocked it and should pencil in a new block.
#2 S pack
  • 15,764 posts
Posted 26 May 2013 - 02:37 PM
Looks like a light hone isn't going to fix that. Bore out to 60 thou OS (if you can get 60thou OS pistons) might be enough if you're lucky or sleeve the cylinder or look for another block.
That said, pics can be deceiving so best to get it checked out by an expert then decide what to do.
Dave.
#3 Bernie
Bernie
  • 301 posts
  • Car:2 lx Hatches and 3 lx 4 doors
Posted 26 May 2013 - 02:46 PM
Every 400 (5 built ) I  have had has had rust stain marks after boring .To date none have had issues as far as leakage of either compression gas out or coolant in .Me I would go with it .
Bernie
#4 S pack
  • 15,764 posts
Posted 26 May 2013 - 04:30 PM
Bernie
To me that looks more like the rust has pitted the bore rather than just a rusty stain mark.
#5 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 26 May 2013 - 04:56 PM
As you said, it may be out of the rings range of travel anyway.
Can't say for sure without looking at it in person but it doesn't look too bad. Worst case it may use a tiny bit of oil.
I am tempted to say hone it and don't lose any sleep.
#6 _434LX_
_434LX_
Posted 26 May 2013 - 04:58 PM
I wouldn't run it like that, but i'm fussy.
+40 th is as far as I would go on a 400. It may pay to check wall thickness anyway before you attempt anything.
Weigh up cost of another block (+machining) Vs sleeves
#7 _doucmyuc_
_doucmyuc_
Posted 26 May 2013 - 05:02 PM
Agree.
Honing wont get that corrosion out. If you hone it and run it, it will wear away under compression and cause low comp for that cylinder.
#8 Bernie
Bernie
  • 301 posts
Posted 26 May 2013 - 05:19 PM
Is it near the siamese side or whereabouts ?
Bernie
#9 _BLOWN V6HATCH_
_BLOWN V6HATCH_
Posted 26 May 2013 - 05:26 PM
I'm with Struggler, if it was mine, i'd be really tempted to hone it and bang it together. I guess the question is, would you be happy with running it as is?
#10 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 26 May 2013 - 07:05 PM
I agree that 40+ seems to be the limit that most are comfortable taking a 400 to and i don't intend on punching this block out any further.
Here is another pic, again taken from the bottom of the bore looking up. The pitting is located about 95mm from the top of the bore so the rings would just come into play (I would need to dig my pistons out to check).
7580a29e-2fac-4706-8002-006a933f421a_zps
This is from the top of the bore looking down. As you can see my bores have crud in them :), the location of the pitting is the stain center of the picture located over the steam hole in the Siamese bore join.
I figure that in a bad situation I'll scrub a set of rings out and have oil consumption or a lot of blow by. In which case Ill drag everything across to a different block.
#11 Bernie
Bernie
  • 301 posts
Posted 26 May 2013 - 07:08 PM
Don't worry about it at all .That is the thickest part of the block .It would have to be through into the other cylinder to cause issues .Whack it together and get them tyres frying
Bernie
#12 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 26 May 2013 - 07:28 PM
BTW that first pic was zoomed in. I was surprised that I got that good a shot of the pitting with my phone.
#13 _BLOWN V6HATCH_
_BLOWN V6HATCH_
Posted 26 May 2013 - 08:34 PM
Honestly, just run a dunny brush type hone down the bores and assemble it. Is it a 4 bolt or 2 bolt 400? If it's a 4 bolt, they're pretty rare as most 400's were 2 bolt as they were pretty much junk smog engines that didn't have to do a great deal apart from lug around a heavy Chev. If it were me and i was concerned about it, i just get a sleeve fitted to that bore and keep that block, especially if it's a 4 bolt as it's definately worth saving.
#14 TempesT
TempesT
  • 493 posts
  • Car:LX hatch
Posted 26 May 2013 - 09:44 PM
Its just a plane jane 2 bolt
Edited by TempesT, 26 May 2013 - 09:45 PM.
#15 _BLOWN V6HATCH_
_BLOWN V6HATCH_
Posted 26 May 2013 - 09:53 PM
Just run a hone down the bores and give it a go.
#16 Bernie
Bernie
  • 301 posts
Posted 27 May 2013 - 08:14 AM
2 bolt is the better one to have .Only has the 2 core plugs on the side like all other smaller small blocks .(harder for Mr Plod to ruin your day) .Can also easily put splayed caps on it and turn it into a 4 bolt with much more strength around the base of the Bearing housings than the 4 bolt factory unit .Just don't get it hot .
Bernie
#17 _Ned Loh_
_Ned Loh_
Posted 29 May 2013 - 06:54 PM
FWIW - I've used a BRM Flex hone for a quick re-ring. Heaps of different brushes availiable to give whatever finish you need to suit rings. Very happy with the results, but get some practice on an old block first as you need good rhythm and the right speed to get a nice cross hatch with the correct angles.
