I know the question has been asked but is it possible to put a UC diff into an LX. I am unsure of its stats but it is currently in a UC. I know some brackets will need to be changed but just thinking width etc?
Will a UC 9inch for in an LX?
_Last-Rites_
, May 29 2013 03:59 PM
6 replies to this topic
_Last-Rites_
Posted 29 May 2013 - 03:59 PM
_Last-Rites_
Posted 29 May 2013 - 04:17 PM
Btw I love autocorrect on iPhones see title
Posted 29 May 2013 - 04:51 PM
The only difference is the upper trailing arm mounts on the diff.
_Last-Rites_
Posted 29 May 2013 - 05:25 PM
So really cut the ones off mine and fit to the diff
Posted 29 May 2013 - 06:00 PM
Fitting new mounts would be the best option. Some people use bent upper control arms to fit the UC into LX.
Once you have welded on new mounts you will need to check the axle alignment in the housing. The housing will often distort during welding. While your at it fit a drain plug if the housing does not already have one.
Something like this
.JPG)
More info here
It would be worth considering using this style of upper control arm mount. Usually you can get some height adjustment and makes it easier to change upper bushes.
Something like this
More info here
Edited by ls2lxhatch, 29 May 2013 - 06:02 PM.
Posted 29 May 2013 - 08:23 PM
Or
Leave the diff alone and change the top mounts on the body
_Last-Rites_
Posted 29 May 2013 - 11:49 PM
Wow thanks guys
