Fitting uc K-Frame to Lx
21 replies to this topic
#1 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 05:22 PM
Can anyone give me some advice.I going to fit new front end to my lx I have the choice of lx or uc complete k frame etc.It will be used for circuit racing and I am going to fully overhaul & was going to replace all bushes and fit 1100 pound king springs and Koni ajustabile
Shocks.
Also does uc and lx steering rack have same ratio.
#2 N/A-PWR
  • 9,636 posts
Posted 09 June 2013 - 05:40 PM
Hi Simon Piv 68,
http://www.gmh-toran...ing-rack-ratio/
#3 N/A-PWR
  • 9,636 posts
Posted 09 June 2013 - 05:58 PM
Here is an example of different leverage lengths which would decide on the ratio's as well:-
http://www.ozrodders...hp?f=2&p=574904
#4 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 06:09 PM
Hi Simon Piv 68,
Cheers for that,would you use original lx front end or change to UC
#5 eyepeeler
eyepeeler
  • 1,959 posts
Posted 09 June 2013 - 06:25 PM
Change to UC. Have a look at my IP thread or my build. Had a few troubles this weekend as you will read!! What class are you setting your Torana up for?
#6 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 09 June 2013 - 06:56 PM
Hi simon.
Use the one in best nick.
The reality is, for a circuit car, all three k frames are identical for your purpose. You are going to modify the k frame for competition anyway so it won't matter.
What will matter, is getting the top UC arms , as they have a different location for the top balljoint which will affect your castor setup.
#7 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 07:20 PM
Thanks fellas, I had set the car up for sprints and regularity events however had an altercation with a concrete barrier at an event in Albany last weekend after a master cylinder problem.I now have to replace right hand chassis rail, two fenders,bonnet,nose cone,radiator support panel,bumper and front end etc etc.So since I am starting from scratch and have scored a couple of donor shells for parts I want to do it the best way possible.I was going to get Wilkinson suspension to put it altogether and set it up.
What are your thoughts
#8 eyepeeler
eyepeeler
  • 1,959 posts
Posted 09 June 2013 - 07:47 PM
Speak to Corey at Malaga Suspension. I bought my gear there.
#9 eyepeeler
eyepeeler
  • 1,959 posts
Posted 09 June 2013 - 07:51 PM
Mind you I bought stuff that A9X and Datto advised
#10 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 09 June 2013 - 07:54 PM
Wilkinson's will look after you.
regarding the steering rack, if you have a number of them for choices ,post the numbers and i'll be able to tell you the ratios.
#11 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 08:26 PM
No worries , I will do that.
ALSO I need to buy front bumper with rubber strip and over riders if anyone knows where I could get one.
#12 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 08:33 PM
What brake setup are you going to use,I was going to use AP calipers that Dattoman advised but my budget is less now I am rebuilding car so I was thinking of wilwood superlites 6 on front and 4spot on back with balance bar pedal setup
#13 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 09 June 2013 - 08:55 PM
take some of the go fast budget and add it to the stop fast budget.
#14 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 09:32 PM
LOL ain't that the painfull truth
#15 eyepeeler
eyepeeler
  • 1,959 posts
Posted 09 June 2013 - 09:49 PM
The options I canvassed were the AP CP5200 4 pot, CP5570 6 pot with a 28mm rotor and what I got which is the CP5555 which I got second hand but un-used through another forum member. I am ordering a 330 x 32mm rotor to suit them. There is heaps of choice!! You may even be able to get some good Ex-NASCAR calipers off EBay? A mate of mine got a great set of AP pedals of Ebay for example. IP require pedals to be within 70mm of original position, so I got a Tilton hydraulic brake and clutch overhung mount 600 series. Brake MC are 3/4 front and 5/8 rear, with the balance bar. I made my own brackets to mount the pedal assembly.
http://www.tiltonrac... Assemblies.pdf
#16 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 10:08 PM
The options I canvassed were the AP CP5200 4 pot, CP5570 6 pot with a 28mm rotor and what I got which is the CP5555 which I got second hand but un-used through another forum member. I am ordering a 330 x 32mm rotor to suit them. There is heaps of choice!! You may even be able to get some good Ex-NASCAR calipers off EBay? A mate of mine got a great set of AP pedals of Ebay for example. IP require pedals to be within 70mm of original position, so I got a Tilton hydraulic brake and clutch overhung mount 600 series. Brake MC are 3/4 front and 5/8 rear, with the balance bar. I made my own brackets to mount the pedal assembly.http://www.tiltonrac... Assemblies.pdf
Cheers for that, I just checked out link for the tilton pedal mount,I have just fitted clutch pedal & mc that came with Tremec gearbox so looks like it might be easier to get rid of that and put twin pedal setup.
#17 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 09 June 2013 - 10:11 PM
did you buy a clutch pedal from Mal ?
#18 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 10:34 PM
Yeah and it's mint so I would like to leave it in,I haven't planned things that well.i bought TKO 600 box off Mal and I am very happy with it
#19 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 09 June 2013 - 10:43 PM
How was the fitment, i've heard mixed responses.
Been tossing up wether to grab one or just make one myself.
I think his prices are a bit north of premium.
if you are happy with it, stick with it and run the standard brake setup.
#20 dattoman
  • 16,487 posts
Posted 09 June 2013 - 10:49 PM
I think I have a balance bar brake setup here off a race torana
Might be abit agricultural for you but you might be able to use it as a template or at least some ideas to make your own if you want to borrow it
#21 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 10:53 PM
Fitment was perfect it all went straight in easy,cost was just over five grand for gearbox,bell housing,clutch,shifter,yoke,clutch pedal and mc but made my own gearbox mount. Do you know if can get single pedal setup for brake
#22 _Piv 68_
_Piv 68_
Posted 09 June 2013 - 10:59 PM
No worries,
