Hi tone horn
15 replies to this topic
#1 2403jam
2403jam
  • 193 posts
  • Name:2403jam
  • Car:LJ GTR and LX SLR
Posted 09 June 2013 - 07:41 PM
Hi guys after a picture of a9x hi tone horn or a they all the same from lh to lx or if someone got one and wants to sell let me no thanks
#2 _outer control_
_outer control_
Posted 10 June 2013 - 01:59 AM
LH LX hi note horns all the same. Wire from low to hi note horn went engine side of radiator support on LH and along front on LX.
LH sl,s used them as well as the SLR and SS,s. Good luck finding one but not impossible
#3 2403jam
2403jam
  • 193 posts
  • Name:2403jam
Posted 10 June 2013 - 08:14 AM
Thanks outer control I need a picture of one I think a mate off mine mite have one thanks
#4 hanra
  • 10,936 posts
Posted 10 June 2013 - 08:21 AM
When you need one there are none around, after you get one they will be everywhere....
Edited by hanra, 10 June 2013 - 08:22 AM.
#5 2403jam
2403jam
  • 193 posts
  • Name:2403jam
Posted 10 June 2013 - 10:02 AM
Your a champ Hanra thanks for the pic now to find one this is best forum on the planet thanks guys
#6 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 23 June 2013 - 09:40 PM
Here I was thinking the high note horn for torana was like on the H series - a curly rams' horn type like the low note.
Never seen one like that Brad..they must be rare then.
I even found me a high note one but I guess it is the wrong type then...bugger!
#7 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 23 June 2013 - 10:31 PM
Brad, i just finished blasting and painting my Hi note horn and put it back together but not sure if there was a gasket either side of the disc to seal it to the body.
#8 hanra
  • 10,936 posts
Posted 23 June 2013 - 10:35 PM
Here is the low not horn.
I think there was a very thin cork gasket. I'll have to re check my pics. Once I re-assembled my horns, I connected it up to the 12v supply on the bench at work and tuned it to draw the current outlined in the manual. That gives them its specific tone.
Edited by hanra, 23 June 2013 - 10:43 PM.
#9 hanra
  • 10,936 posts
Posted 23 June 2013 - 10:55 PM
Yep. Very thin gasket. I remember now.
#10 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 23 June 2013 - 11:03 PM
damn, now i gotta get some fine gasket paper.
Thanks Brad.
#11 hanra
  • 10,936 posts
Posted 24 June 2013 - 06:22 AM
I think I bought a sheet off eBay!!! No one up here had anything thin enough.
#12 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 24 June 2013 - 08:13 AM
Thanks Brad.
 Weet-bix box. The bushies gasket. Works for everything from thermostat housings to whatever.
The "low not"  horn is what I got. Used on on Premiers & Statesmans and they sound very USA as a pair. Guessed they used the same. I had a spare left over from my Premier rebuild.
Edited by mika03au, 24 June 2013 - 08:18 AM.
#13 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 24 June 2013 - 04:02 PM
Thanks Michael, will give it a go.
#14 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 25 June 2013 - 02:43 PM
That'd collect water, wouldn't it be a rust opportunity?
s
#15 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 25 June 2013 - 03:50 PM
s
You might be right, I have used it on the thermostat housing without issue. (roadside leak fix out back of nowhere)
Perhaps Mort you might try the proper gasket sheet.
It would be terrible your hooters ( ;) ) rusting after all that effort to rebuild it.
#16 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 25 June 2013 - 05:16 PM
Nobody likes looking at a pair of old worn out hooters.
s
