1972 Torana LJ four cylinda front end
17 replies to this topic
#1 _Rodney-Allen_
_Rodney-Allen_
Posted 07 July 2013 - 07:49 AM
Can someone please tell me if the four cylinder lj torana 1972 came out with the same front end as the TA or HB, I have a 1972 lj Torana 2 door sedan that i am trying to sell but am getting a lot of negitive feed back suggesting it is not a LJ at all, The compliance plate says it is a LJ but because the front end does not have the point on it a lot of people are questioning the model.
Cheers Rod Allen
#2 rodomo
  • 18,025 posts
Posted 07 July 2013 - 07:54 PM
Pics?
#3 _Bomber Watson_
Posted 07 July 2013 - 08:02 PM
4 cylinder is more or less the same sheet metal hb through ta, lc and lj included.
There are some minor changes bit nothing the average punter will pick, and by the sounds these lads giving you feedback are a fair bit below the level of the average punter.
#4 limo
limo
  • 2,672 posts
Posted 08 July 2013 - 02:26 PM
Should say LJ on tags and chassis number.
#5 _mikecatts_
_mikecatts_
Posted 08 July 2013 - 05:58 PM
 I know the car you are trying to sell.. Its  a LJ 4cyl...
pic of 71 LC 4 cyl coupe..
#6 _mikecatts_
_mikecatts_
Posted 08 July 2013 - 06:04 PM
4 72 LJ 4cyl coupe..original front..
#7 _LONA-CK_
_LONA-CK_
Posted 08 July 2013 - 06:23 PM
Up for aution is a 1972 LJ Torana Coup.
There is rust in the usual places eg: front quarter panels, minimal rust in the back quater panels, divers side sill is quite bad the passenger side is fine.
Seats will need replacing or reupolstered.
I have had a lot of emails about the model of this car because of the shape of the front end, i am no expert on toranas but the compliance plate says 1972 LJ 2 door sedan
The car does need some work but everything is there, nothing missing, and would make a great project for someone
The motor had a bad oil leak when i parked it in the shed but it was running.
I suggest you come have a look at it but will be happy to try and answer any questions
Call Rod 0412236475
this is taken from your add on ebay it is a 4 cyl lj 72 model other than that rod tell them piss off.
ps what sort of dollars are you chasing for the car and what nik are the rear quarters in rust wise???
cheers gong
Edited by LONA-CK, 08 July 2013 - 06:26 PM.
#8 blown308
blown308
  • 2,328 posts
Posted 08 July 2013 - 09:03 PM
exact same this is also tag an LJ 12/73 model
Edited by blown308, 08 July 2013 - 09:06 PM.
#9 blown308
blown308
  • 2,328 posts
Posted 08 July 2013 - 09:15 PM
http://www.uniquecar...oor_LJ_1300.pdf
http://www.uniquecar...oor_LJ_1600.pdf
Edited by blown308, 08 July 2013 - 09:17 PM.
#10 blown308
blown308
  • 2,328 posts
Posted 08 July 2013 - 09:19 PM
also dont how much of this is helpful
http://www.uniquecar...cifications.htm
#11 Potta
Posted 08 July 2013 - 09:42 PM
Cheers Rod Allen
Sound like they haven't heard of 4 cylinder Toranas.
None of them had the point, only the 6 Cylinder versions.
Assuming they can read, they may find this helpful - https://en.wikipedia...i/Holden_Torana
#12 Dr Terry
Dr Terry
  • 3,315 posts
Posted 09 July 2013 - 07:40 AM
But that looks like a 74/75 TA Torana.
Dr Terry
#13 _LONA-CK_
_LONA-CK_
Posted 09 July 2013 - 08:11 AM
i had one of these same color combo, real nice set up for a young girl.
Dr Terry
doc would be spot on it was just the change over time.
cheers gong
#14 S pack
  • 15,666 posts
Posted 09 July 2013 - 08:43 PM
The 4 cyl Torana bonnet has a point, just not as big as the 6 cyl.
#15 Potta
Posted 09 July 2013 - 10:47 PM
Yeah, I see now, but look, this is from the ad.
Attached File  LJ4cylnose.PNG   223.39K   1 downloads
Edited by Potta, 09 July 2013 - 10:47 PM.
#16 S pack
  • 15,666 posts
Posted 09 July 2013 - 11:07 PM
LC grille!
Link to the ad.
http://www.ebay.com....=item2c7085af06
Edited by S pack, 09 July 2013 - 11:15 PM.
#17 _dagsy_
_dagsy_
Posted 10 July 2013 - 08:38 PM
has got HB front end except for a different grill . so I suppose you could say it is a Lj coupe/HB hybrid of sorts. which is what a TA is. LJ from the a pillar back, HB forward.
Edited by dagsy, 10 July 2013 - 08:41 PM.
#18 _mikecatts_
_mikecatts_
Posted 11 July 2013 - 07:02 AM
You said it.. Im stripping a 1968 HB at the moment and the front end is EXACTLY the same as the LC and LJ 4cly....
