I will take a photo and measurements of an unmolested A9X to try to clear up the reasons why cheap ass holden did what they did to the A9X. Yes the stubs drop it by around 20mm but it uses 14" rims vs 13" rims and that counters the 20mm back to std ride height. Without pulling the A9X to bits I think if you measure free height to loaded height vs std torana springs you will find a bees di#k in ride height (once broken in). Its not like Toranas need ground clearance for off-roading. Ride height would be the same but of course the HD springs wouldn't compress as easy (firm ride).
The big limited travel blocks in the A9x are just because it was a slapped together system adapted from the HX/HZ (which has far more room under the guards). You have to remember it was all done for the race teams and bigger brakes to meet homologation requirements. Think holden mentality aka HQ bumper on LE Monaro its just throw on what they had and make it work. We are not talking Ferrari here, engineering and penny pinching in the 70's at holden was pretty crude and rude.
The A9X steering arms (P/N 92001893 and 4) where only required for bump steer correction when using the H series stub axle. Holden didn't fit them because it had fitted the front springs (P/N 9931027) in the A9X. Otherwise when Holden delivered every other torana with the optional P/N 9931027 springs it would have the same poor bumpsteer the A9X has if you used the standard torana steering arms.
I can assure you its was the H series stub axle usage that required new steering arms.
All of what you say makes perfect sense, except Holden slapping the HQ rear bar on the LE as being cheap. It was actually a HJ rear bar, as the LE was a HJ body. Most of the W size Holdens and Statesman kept the HQ rear styling, only sedan and wagon changed at HJ introduction. Van, ute, coupe, tonner and Statesman kept the HQ rear quarters and beaver this kept the HQ rear bar(s). Statesman did get a different bar as the tail-lights changed but the back end was still HQ. It wasn't until WB that the Statesman got a HJ sedan/wagon back end. I din't see this as cheap, it is just economics as sedan and wagon were the volume sellers and hecne it was justifiable to engineer in some stying upgrades. For the small volume of coupes (like 943 HJ plus the 580 HJ bodies made into HX's) the added cost per car would not have been acceptable.
I don't see the use of HX stubs on the A9X as being cheap either, it makes sense to do it, ie use an existing part to build a homolgation special!
Edited by yel327, 17 August 2013 - 11:31 AM.
