control arm wot is the difference from left and right
5 replies to this topic
#1 _robbo_
_robbo_
Posted 09 August 2013 - 02:43 PM
is there a difference from left and right upper is the one  i would like to know  thanks again robbo
#2 arrimar
arrimar
  • 3,134 posts
Posted 09 August 2013 - 04:01 PM
If its a UC upper arm it'll matter as the ball joint is offset towards the rear, they're marked for id. LH and LX are ball joint on centre and should be able to switch. Don't know about the early models Robbo, expect they'd be switchable. See what others say.
#3 _robbo_
_robbo_
Posted 09 August 2013 - 04:50 PM
thanks mate they look the same but you r the first to reply so i hope someone else helps to lots of looking but no reply someone help
#4 S pack
  • 15,687 posts
Posted 09 August 2013 - 05:08 PM
Are they stamped R on one arm and L on the other arm? If not then they are identical.
#5 _robbo_
_robbo_
Posted 09 August 2013 - 05:19 PM
no i don't think not that i could see but i will have a good look at them for it now
#6 ls2lxhatch
  • 5,332 posts
Posted 10 August 2013 - 02:09 AM
The right side UC is stamped with a R. The left is not stamped but is easily identified by the offset ball joint.
LH/LX are symmetrical.
Edited by ls2lxhatch, 10 August 2013 - 02:09 AM.
