turbo trans bolt patterns start?
16 replies to this topic
#1 _muz_
_muz_
Posted 18 August 2013 - 10:51 AM
hi guys
i need to get a 5litre with a turbo trans bolt pattern for a conversion on my Patrol.
was wondering if anyone knows an easy way to tell the bolt patterns apart,
and when they were made from.
im after a carby version.
thanks in advance :)
Muz :)
#2 76lxhatch
  • 7,205 posts
Posted 18 August 2013 - 11:08 AM
In my opinion the quickest/easiest way to tell them apart is to look at the top bolt locations. If you look at the rear face of the block there are two bumps at the top corners that are designed to give extra meat around the top bolts, like a boss. The Holden pattern places the top bolt holes nicely centred within this boss area, the Chev pattern does not (the bolt holes are a little lower and it looks like the extra meat at the bumps/corners is pointless).
#3 _muz_
_muz_
Posted 18 August 2013 - 11:10 AM
ok cool, thanks for that 76lxhatch :)
it gives me some help as to watch out for :D
#4 dattoman
  • 16,487 posts
Posted 18 August 2013 - 12:36 PM
Everything VN on will be Turbo pattern .. then convert to carb
Statesman blocks are usually Turbo pattern and engine numbers can start with 11QT
BELLHOUSING+TOYOTA+SUPRA+TO+WB-HZ+COMMOD
#5 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 18 August 2013 - 06:40 PM
This ones turbo pattern. In this case VT.
#6 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 18 August 2013 - 09:30 PM
I reckon the easiest way for a novice is to check the bellhousing dowel size.....
Tri pattern use a 1/2" dowel, turbo pattern use a 5/8" dowel. Grab a 1/3" or 13mm open end spanner and see if you can slide it over the dowel, if you can it is a Tri pattern, if not it is a turbo pattern !
#7 ls2lxhatch
  • 5,332 posts
Posted 18 August 2013 - 11:25 PM
Another picture from this thread.
#8 yel327
  • 13,633 posts
Posted 19 August 2013 - 08:28 AM
HJ to about 11/81, so about 9/74 to 11/81, but only auto blocks and not HT or HZ prefix Torana blocks. The engine number prefixes you need to look at are:
QT, 11QT, ZT, 11ZT, VT, NT, WT, 11WT, 12WT, N5T, BS.
Some of these can be manual or auto.
#9 yel327
  • 13,633 posts
Posted 19 August 2013 - 12:15 PM
Edit,
Edit, brain snap. Erase BS from the above and add BV. BS is a TH pattern low comp 253. BV is the same but a 308.
#10 _muz_
_muz_
Posted 23 August 2013 - 12:53 PM
Thanks for the heads up guys.
you have made it a LOT easier.
was looking at a VL 308, wasnt sure about it, but easier to tell now.
when switching across from EFI to carby is it just the manifold to change on VN-VT?
#11 yel327
  • 13,633 posts
Posted 23 August 2013 - 01:22 PM
VL is a trimatic pattern, and no good for you as it has all sorts of ULP implications etc.
You can't use a VN-VSIII engine with a carby and have legal rego unless you run straight LPG. But to run a carb on one of these just remove the EFI valley cover and put on a carby valley cover, there are a few like Harrop, Redline etc that fit the VN-VSIII heads. An early dizzy will go straight in. I wouldn't use a VN-VSIII 304ci engine with a carby in a 4x4 though, the ports in the heads are too big and the engines are too doughy down low. I stuck one of these is my HZ Holden Overlander, it was a standard VP engine with a manifold and carb, it badly lacked low end torque. Best bet is to find a whole blue motor in TH pattern. What year Patrol are you modding?
Edited by yel327, 23 August 2013 - 01:23 PM.
#12 _muz_
_muz_
Posted 23 August 2013 - 08:11 PM
thanks yel327.
got a GQ 1989
#13 yel327
  • 13,633 posts
Posted 23 August 2013 - 09:03 PM
I'd just use a whole VN-VSIII engine. Get it Engineered etc. build yourself a 350 stroker later if not powerful enough. Or talk to Marks4WD about a Gen3 conversion.
#14 _muz_
_muz_
Posted 27 August 2013 - 08:50 AM
its a marks4wd kit that im getting, it was a good price.
#15 yel327
  • 13,633 posts
Posted 27 August 2013 - 10:55 AM
I'd still use the whole EFI engine.
#16 _muz_
_muz_
Posted 28 August 2013 - 03:14 PM
i'd like to, but the wiring scares me :(
#17 yel327
  • 13,633 posts
Posted 28 August 2013 - 04:35 PM
Marks sell the whole harness ready to go with relays etc.
