DIY tools
106 replies to this topic
#76 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 28 October 2014 - 05:55 PM
Hahaha, lead fixes all sorts of things people included. lol
#77 _judgelj_
_judgelj_
Posted 31 October 2014 - 05:05 PM
Those wheels are awesome
#78 Shtstr
Shtstr
    Formerly lcxu105
  • 1,810 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 19 January 2016 - 12:17 PM
Made one years ago. We used a valve stem from a tubeless tyre in an old master cylinder cap to bleed brakes.
Edited by lcxu105, 19 January 2016 - 12:21 PM.
#79 Shiney005
  • 9,536 posts
  • Car:Toyota Mirai
Posted 27 March 2019 - 11:01 PM
https://youtu.be/_O61sTY67W8   Easy to make metal bender.
#80 _Lazarus_
_Lazarus_
Posted 24 April 2019 - 11:07 PM
Link doesn't work
#81 claysummers
claysummers
  • 3,600 posts
  • Name:Clay
Posted 25 April 2019 - 11:32 PM
That’s cool
#82 _Gunmetal LH_
_Gunmetal LH_
Posted 30 April 2019 - 12:31 AM
Found this next to a 10mm socket I had lost.  Thought I'd show you.
3am on a Sunday morning, everything is nearly undone on a VN trans, and I can't get the cooler lines undone!
Need the car Monday morning- couldn't wait...
Attached File  DSC_2357_2.jpg   84.58K   13 downloads
#83 Com_VC
Com_VC
  • 411 posts
Posted 30 April 2019 - 06:58 PM
good idea
#84 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 01 May 2019 - 12:02 AM
Out of necessity and budget i made a camshaft  bearing and install tool
from a 600mm post stirrup, threaded rod, a torana K frame to chassis bush and some large washers.
#85 76lxhatch
  • 7,202 posts
Posted 26 April 2020 - 12:07 PM
Not a DIY tool, but a DIY repair of one. Broke the moving jaw on my milling vice some time ago, was sort-of planning on replacing it but not overly cheap. Then suddenly we're all under house arrest and I want to use it and can't get a replacement.
Milled the remains of the broken casting flat. Found some solid steel of suitable size and machined a bolt-on piece to replace the broken part. The jaw is drilled and tapped for two high tensile cap screws.
Vice is once again operating properly. Has seen a fair bit of use the last few weeks and no issues.
Even with some minor abuse...
#86 dattoman
  • 16,487 posts
Posted 26 April 2020 - 01:05 PM
I'm planning on having a go at making my own sheet metal press brake soon... hopefully
And by soon...I mean in the next few years... like all my projects... lol
#87 46Crab
46Crab
  • 16 posts
  • Car:LH Sedan
Posted 26 April 2020 - 02:11 PM
Scrap bin engine lifter for a red 6.
Works a treat..
Your photos aren’t showing, but I’ve noticed you are using photo bucket.
#88 claysummers
claysummers
  • 3,600 posts
  • Name:Clay
Posted 26 April 2020 - 09:46 PM
As we did, in 2014............................................... 8) 8)
#89 rodomo
  • 18,032 posts
Posted 26 April 2020 - 10:39 PM
It was probably made out of Wild Turkey cans and pop rivets? :fool:
#90 rodomo
  • 18,032 posts
Posted 28 April 2020 - 11:49 PM
A forum member asked how to change control arm bushes in my thread.
The bolt and nut are hi-tensile 1/2" UNF. This fine thread should give enough pressing power to remove and refit and will also do the 2 in the diff housing as this can't be done in a press. The 1/2" shank will also provide good alignment as that is the size of the hole through the bush.
The spacers are either exhaust pipe or tail shaft. The washers are rear top shocker mount washers or flat plate with holes drilled.
The important bit is the "U" shaped piece which should be fitted on removal and replacement of bushes to avoid distortion of the arms.
The long bit is for front upper control arm bushes as not to crush the arm when pressing in new bushes.
Note: LC/J rear control arm bushes are the same as LC/J front lower control arm bushes and the "U" shaped piece should be used there also.
Edited by rodomo, 28 April 2020 - 11:59 PM.
#91 Rockoz
Rockoz
  • 4,021 posts
  • Name:Rob
Posted 29 April 2020 - 09:42 AM
That lathe looks a lot like mine, albeit with a different name.
What is its Hare and Forbes model number please?
I needed a part for mine, and I rang Hare and Forbes, thinking that they would have had something similar.
The bloke who answered the phone was an absolute drop kick.
Wouldnt even take a little time to help me.
I had just spent about a grand with them buying bits and pieces, so I wasnt particularly happy.
Great little lathe to use.
Edited by Rockoz, 29 April 2020 - 09:43 AM.
#92 76lxhatch
  • 7,202 posts
Posted 29 April 2020 - 10:08 AM
This would be the current model:
https://www.machiner...51G-Bench-Lathe
Mine is slightly older being an "AL51" rather than "AL51G", but there are only very minor differences so everything should interchange.
The biggest problem with it is the tiny little V belt, it likes to snap and they are quite expensive. Gates part number is 5M710 (5mm belt 710mm long, who would have thought) and prices vary wildly if you shop around.
#93 76lxhatch
  • 7,202 posts
Posted 08 June 2020 - 03:19 PM
Here's another that just saved me, needed a pin puller for the 1/8" retaining pins in a Trimatic main body. There is less than 5mm of the pin to grab and under 10mm diameter around one side of them, and they were tight enough for the quick-and-dirty methods to be of no use.
Started with an old M12 stud from the junk pile, cleaned up.
Turned the end down to 6mm OD and drilled a 1/8" hole in the centre, retaining enough thread to be usable.
Carefully cut three slots with a tiny 0.4mm cutting disc (or six, they fly apart if you so much as glance at them sideways).
Made a special nut out of some bar stock (cut shank off old 3/4" bolt).
Which results in the stud having a tiny little collet on the end.
Add some impact, and it works!
#94 claysummers
claysummers
  • 3,600 posts
  • Name:Clay
Posted 08 June 2020 - 09:26 PM
Clever
#95 rodomo
  • 18,032 posts
Posted 08 June 2020 - 09:48 PM
:spoton:
#96 Rockoz
Rockoz
  • 4,021 posts
  • Name:Rob
Posted 09 June 2020 - 12:46 PM
Thats just showing off now.
Guessing you have a dremel handy as well.
I bought a knock off one, then decided I wanted a decent chuck for changing tools.
Bought the dremel one and it didnt fit the knockoff, so bought a dremel as well.
Im scared to add up the cost of the stuff I have bought since not working, recovering from injury.
Ebay and Wish have seen me buy too much. Or is there ever really too much??
Rob
#97 76lxhatch
  • 7,202 posts
Posted 09 June 2020 - 02:59 PM
Thanks, I must admit to being a little surprised when it worked first time!
Rob if you mean for cutting the slots, I just used the air die grinder. I find collet chucks better than adjustable, all tools for the die grinder is either 1/8" or 1/4" (or 3mm/6mm which is close enough). I even use an ER20 collet chuck on the drill press 99% of the time now, much better than the adjustable chuck.
Can never have too many tools, but I am starting to find that they are way too expensive these days.
#98 Shiney005
  • 9,536 posts
  • Car:Toyota Mirai
Posted 19 October 2020 - 09:56 AM
I'm not stretching the boundaries of science with this one, but it is something my old man taught me in the 70's and I have found it very useful over the years.
U shackles have a habit of doing themselves up tight if the chain they are attached to comes under tension.  This little trick just means you don't have to go looking for a crescent to get them undone.
I used a 50x2.5mm nail for this size pin.
Attached File  IMG_1917.JPG   346.65K   4 downloads
My old vice wont allow me to bend the nail right over.......
Attached File  IMG_1918.JPG   271.94K   5 downloads
so I drilled a 2.5mm hole in a bit of plate and used it to get the bend tight enough to get it back in the vice for the final squash.
Attached File  IMG_1920.JPG   211.27K   4 downloads
Attached File  IMG_1923.JPG   294.27K   4 downloads
Attached File  IMG_1922.JPG   341.04K   4 downloads
#99 Shiney005
  • 9,536 posts
  • Car:Toyota Mirai
Posted 19 October 2020 - 12:43 PM
I also knocked up the oil filter adaptor for priming the Holden oil pumps that Koalasprint came up with a couple of years ago.
The Group A hadn't been out of the shed for five years. Needless to say, it had no oil pressure when turning it over with the key.  I was also bitterly disappointed with the lack of barn find dust.
Attached File  IMG_2073_Moment.jpg   121.67K   6 downloads
I cut the end off a Wesfill filter, and found that an old exhaust from a 5hp honda, and the fuel line from a Landcruiser are about the right sizes for the mods.
Attached File  IMG_2062.JPG   289.8K   7 downloads
Two flat washers were the only other parts needed.
Attached File  IMG_2063.JPG   300.74K   7 downloads
Attached File  IMG_2065.JPG   243.67K   5 downloads
Attached File  IMG_2066.JPG   200.24K   6 downloads
Edited by Shiney005, 19 October 2020 - 12:44 PM.
#100 Shiney005
  • 9,536 posts
  • Car:Toyota Mirai
Posted 19 October 2020 - 12:48 PM
After drilling the filter end right through the larger of the washers, it is just a matter of brazing in the fuel pipe.
Attached File  IMG_2071.JPG   235.04K   7 downloads
I found a hand pump in Auto One ($9.00) and attached it with some tubing. It took about ten seconds of pumping to have oil flowing through the clear tube. It had no trouble sucking the oil through the pickup and pump and all the way through the motor.  It worked a charm.
Attached File  IMG_2074_Moment.jpg   220.54K   10 downloads
