LJ Bonnet alignment
5 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 08 October 2013 - 08:04 PM
Too all the panel beating guru's.
My bonnet sits lower against the passenger guard.  This guard has been replaced at some stage and I'm looking for a way of fixing this without removing the guard.  Hey, it may be the bonnet is flat in that area?
Fits nice at top and bottom but about 40cm from top the guard sits about 3-4mm higher. See pics.
Attached File  IMG_3866.jpg   43.48K   5 downloads
Attached File  IMG_3867.jpg   22.68K   3 downloads
Attached File  IMG_3868.jpg   32.62K   3 downloads
Attached File  IMG_3869.jpg   23.54K   3 downloads
Attached File  IMG_3870.jpg   22.38K   3 downloads
Guard does seem to curve up more than the drivers side, my immediate thought is to run a grinder down the upright section of the guard so it can be pulled down and rewelded.?
Any thoughts?
Marty
#2 S pack
  • 15,722 posts
Posted 08 October 2013 - 09:42 PM
Marty,
Dress the edge of the guard down with a block of wood and a hammer or dress the edge of the bonnet up to match the guard.
Most important thing is to work out if it's the guard or the bonnet that is wrong.
Dressing the edge of the bonnet will be the easiest.
#3 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 19 October 2013 - 08:06 PM
Thanks Dave, I had a panel beater friend of a friend come over for a look at some problems. Here is what he suggested and it worked. Attached File  ImageUploadedByTapatalk1382177042.412805.jpg   53.5K   1 downloads. I gave it a few good wacks and a great result with minimal damage. Attached File  ImageUploadedByTapatalk1382177135.446258.jpg   43.68K   1 downloads
#4 Potta
Posted 19 October 2013 - 08:35 PM
bewdiful!!
Nice work Marty, it would have been a shame to have everything perfect except for that.
#5 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 19 October 2013 - 11:47 PM
Hi Craig, Should see what I've done to the other side to get a gap correct. Very scary! Attached File  ImageUploadedByTapatalk1382190457.004430.jpg   117.25K   2 downloads
Edited by sibhs, 19 October 2013 - 11:48 PM.
#6 S pack
  • 15,722 posts
Posted 20 October 2013 - 08:10 AM
Good on ya Marty.
There's always a solution to a problem.
Dave.
