The only bits being done repro are these little bits in front of the mirrors which is good because they have always been stinkers to get.
http://www.ebay.com....#ht_1482wt_1161
Those are SS ones as they have the slotted holes in 1 end, the SL ones just tuck under the end of the mirror but you can make them work for both.
I still use the original SL ones on mine with SS mirrors as I have yet to find someone willing to part with the SS set for a reasonable price and they all seem to have marks of some sort on them.
The SL mirror base is about 10mm longer so you end up with a 10mm gap behind the mirror if you use the SL ones. A fair few of the SL passenger side ones didn't have mirrrors so they are 1 piece which you can carefully mod to take a mirror, which is what I did.
The original SS ones above do look good without that little 10mm gap.
There is no rain gutter trims for the hatchbacks - they all go round the windows (under the rain gutter at the top) as per the pic of the blue one above.
