well i think i might be up the shit goin na-t with the ge,because of the higher comp,the gte gasket will work, the gte 1.3mm ,will be restricted to low boost,and detonation, i will be retaining the ge block with out oil squirters,there is 6 holes for squirters,ge has only one so im thinking lower oil pressure will be a prob ,they say 80psi comes out of them squirters pointing up under piston,now if you think of that imagine the piston tryin to go down against 80psi squirting up at you,would like to know what anyone has to say about that,if i go the ge head like i mentioned will be limited to boost,and then have to block off the ignition and run a crank trigger setup,this is startin to be a pain in the arse.so the blocks are identical minus squirters ,so is it the gte head i need or is there a difference in block height to ge block?to lower comp,ive read a little bit not much as i know stuff all on the mechanical side of things,
either i have to get a gte ecu,or aristo ,and gte loom,and gte map sensor,coilpacks etc,or will i do what you did rowy piss off the wiring and then go after market ecu etc,
