LX steering column shaft length
21 replies to this topic
#1 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 12 January 2014 - 07:15 PM
As above would anyone have a shaft out or laying around they would be able to run a tape measure over
Have an issue with the shaft not protruding through the bottom bearing on re assembly
I don't think the shear pin has gone but just need to confirm
Seem to remember a thread on a problem similar to this but cant seem to find it
#2 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 12 January 2014 - 07:33 PM
ullo mate.
as it happens, i have 3 on the bench at present. One complete refurb, one in the middle of recon and one standard.
You won't like my answer.
I have 3 measurements !! :)
from end to end longest is 920mm, shortest is 905 mm
None of the three have free movement between the 2 pieces.
When i pulled the young blokes column apart in his LH , which had a hard front rh hit at some stage that bent the column , the centre shaft pieces were easily moved in / out by 50 mm.
Best wishes mate
#3 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 12 January 2014 - 10:44 PM
Cheers Mark
I have 895 and the main shaft is just inside the lower bearing with the top end assembled
I need another 20mm for it to be completely through the lower
Doing my head in as to why  - it was fine when it come apart
Tried to pull it apart but nowt movement
Where's that PM?
#4 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 12 January 2014 - 11:25 PM
pm on its way, thanks for reminding me mate.
#5 S pack
  • 15,730 posts
Posted 12 January 2014 - 11:56 PM
Can you post a pic of the top end of your column where the steering wheel goes on?
#6 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 13 January 2014 - 09:59 AM
Will do tonight Dave
PM sent back Welby
#7 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 13 January 2014 - 08:33 PM
Top end
Lower end
You can see the main shaft just inside the bearing
#8 S pack
  • 15,730 posts
Posted 13 January 2014 - 09:18 PM
Thanks for the pics Dave.
Looks like you assembled the top end of the column correctly so the only logical conclusion, if you are using the original shaft and column jacket, is your shaft has collapsed. You say in your 1st post the shaft was protruding through the lower bearing when you dismantled the column but on reassembly the shaft is now too short. At some stage in the rebuild you may have inadvertently collapsed the shaft and not noticed. The sheer pins may have already been broken before you pulled it apart.
#9 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 13 January 2014 - 09:36 PM
Cheers Dave
Back apart it is then
1 step forward and two back - just had to check
#10 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 13 January 2014 - 09:47 PM
you could try just pulling on the bottom part of the shaft
#11 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 13 January 2014 - 10:28 PM
some pics for you mate
#12 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 14 January 2014 - 09:15 AM
Yeah have tried pulling the shaft Mark
Thanks for the photos -- just the trick
Will compare them to what i have tonight - it's the black wires i have the issue with
There has been a bit of chopping and swapping gone on
Edited by Swarbs, 14 January 2014 - 09:16 AM.
#13 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 14 January 2014 - 01:55 PM
while you are playing around, here is an old thread about replacing the bottom bearing.
http://www.gmh-toran...-uc-bottom-brg/
#14 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 14 January 2014 - 03:04 PM
Nice read - havn't seen devilsadvocate on here for a while
Will be sticking with what Mr Holden put there though with maybe just a dust cover over the bearing protruding to keep the grease in and the sh!t
out - still does the same job
#15 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 17 January 2014 - 05:32 PM
Mark you havn't got an earth location point for the two blacks have you
Presume looking at them and the length of them it is the same point
Short one from the clip is earth for the dash
Long is from the switch
#16 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 17 January 2014 - 07:44 PM
yep, the long one earths to the column itself. Phillips head screw half way up the column. I'll gete a pick and i'll confirm the earth loc on the short one when i get home.
#17 MRGMH
MRGMH
  • 228 posts
  • Name:Torana
  • Car:LJ
Posted 22 February 2020 - 03:22 PM
Hey mate do you have a picture of where the earths go? Thanks
#18 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 12 March 2020 - 07:30 PM
Mark I don't think has been on for a while  - I am down south so can't help
Someone else?
#19 christolx
christolx
  • 184 posts
  • Name:Chris
  • Car:1976 LX SL Coupe
Posted 24 May 2020 - 06:03 PM
Hi Guys,
I am re-fitting my steering column and am finding that the mount which fits the column up to the dash is too short and does not line up with the bolt holes. I thought it may have been due to my column being collapsed so I put an old steering wheel on and wacked it with a hammer a few times to try and extend the column...(which I think it did) as now the upper bearing that fits in the coffee pot has moved forward and is currently out of the housing. BUT...the column and bracket did not move with it and I'm confused to why it is short? Where  could I have I lost length in this? could it be from the length of shaft that is pushed into the flexible coupling? I am pretty confused... :blink:
Attached File  IMG_20200524_153825.jpg   101.64K   2 downloads
#20 76lxhatch
  • 7,208 posts
Posted 24 May 2020 - 06:38 PM
To move the entire outer column further inside/outside the firewall un-do all three bolts and twist the whole thing using the mounting bracket as a handle, a little lube on the rubber firewall grommet helps (e.g. a touch of spray on CRC). At least one (if not all depending on how much movement you need) of the unis in the engine bay will also need to be loose to allow the inner column to move with it.
If you just need to move the bracket a little relative to the outer column, there is a bit of a slot in the holes where it bolts to the column, un-do those and slide it up or down.
#21 christolx
christolx
  • 184 posts
  • Name:Chris
Posted 24 May 2020 - 07:51 PM
ah yep, I thought I might have to undo the uni's...which will likely mean removing the cotter pins again...
Ok I'll give it a crack & can hopefully get it all to line up! thanks heaps bud!  :spoton:
#22 christolx
christolx
  • 184 posts
  • Name:Chris
Posted 24 May 2020 - 10:18 PM
Sweet! that did the trick...had to slide those shims down ever so slightly but we're good! :clap:
