aussie 4speed box need one heres the link to get a tough box
M20 M21 reco boxes
9 replies to this topic
#1 _aussie4speeds_
_aussie4speeds_
Posted 02 February 2014 - 02:06 AM
http://freewebs.com/aussie4speeds/ check my site out tell me what you think guys or if you need one go to contact me for order page cheers !!!
#2 _aussie4speeds_
_aussie4speeds_
Posted 02 February 2014 - 02:24 AM
Note:the mitsubishi bearings i use are a heavy duty high capacity high clearance C3 doubble sealed bearing with a rev range up to 9000 revs so it can handle all modified high reving engines we only use quality parts in my boxes thats why they hold up so well and last a long time ......
#3 N/A-PWR
  • 9,639 posts
Posted 02 February 2014 - 02:29 AM
Thank-you Aussie for your Expertise. Dave i
#4 _76S.L.R_
_76S.L.R_
Posted 02 February 2014 - 11:38 AM
I ended up blowing up 2 x  M20 Boxes,within 2 years in the LX when I first bought it and it was only a (Mild) 308 both of them striped teeth of second gear!!,do yours still use the standard Gears??
#5 _Bomber Watson_
Posted 02 February 2014 - 01:27 PM
Why isnt this in the business section and are you contributing to the forum financially?
#6 _aussie4speeds_
_aussie4speeds_
Posted 03 February 2014 - 12:11 AM
yes we use the standard gears but we have fixed holdens design faults check us out on our web site here is the link http://freewebs.com/aussie4speeds/  and see what we do to make them hold up to 355 strokers cheers !!!
http
because tory said it would be better here ....
#7 _parsons5000_
_parsons5000_
Posted 04 February 2014 - 09:52 PM
HAhaha I wouldn't bother with a m21
#8 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 04 February 2014 - 11:37 PM
ryan
some of us with original factory standard cars have no choice!
other than those lucky ones that had dealer fitted T10's
have to treat the old M21 gently these days
#9 rodomo
  • 18,037 posts
Posted 05 February 2014 - 09:09 PM
Aussies are delicate in the lower gears regardless of horsepower.
They are simply not  strong enough in the cluster/layshaft bearings.
BUT..................they are cheap to repair.
#10 _aussie4speeds_
_aussie4speeds_
Posted 06 February 2014 - 12:01 AM
that's why we use the ford top loader lay shaft and rollers its much larger and makes the box tougher
  see we bore the cluster insert steel sleeves and bore the case see  this modification makes it hold up to 355 stroker
I have not had a race box come back yet .....
