LH 308 heater hoses
13 replies to this topic
#1 samslr
samslr
  • 46 posts
  • Name:Gino
  • Car:lh slr 5000 Ducati ss 750
Posted 26 February 2014 - 08:21 PM
Hi all,
   I as wondering if any one knows if heater hoses are available for a lh 308 I see rare spares have a kit for lx am I right is
saying that they different from lh any advise would be great
#2 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 26 February 2014 - 08:31 PM
Try SSTORANA  a member here.  He does stuff through his Torana repo business.  Good stuff too.
#3 _Tony.p2_
_Tony.p2_
Posted 26 February 2014 - 08:35 PM
Hi Mate
I got a set from Supercheap auto for around 30$ that were close enough in length and had a 45 deg bend (to come up from the water pump and over the inlet manifold).I then cut to the desired length and fitted.
Tony
#4 _LHSL308_
_LHSL308_
Posted 26 February 2014 - 09:18 PM
Yep your right Gerry. I bought mine from SSTORANA as well for my LH 308 and not only are they really good quality but they fit perfectly. Just  get these ones, you wont be dissappointed. Heres the ebay link to his set.
http://www.ebay.com....984.m1423.l2649
#5 hanra
  • 10,936 posts
Posted 26 February 2014 - 09:37 PM
LH heater hose routing is totally different to LX which is what that eBay kit linked above is to suit.
#6 _LHSL308_
_LHSL308_
Posted 27 February 2014 - 09:05 AM
Lets not get fuddy duddy Brad :D
#7 hanra
  • 10,936 posts
Posted 27 February 2014 - 10:00 AM
LX with 27a does not use the same type of thermostat cover and possibly not even the same type of inlet manifold layout?
#8 TerrA LX
Posted 27 February 2014 - 10:05 AM
There are three red motor Torana manifold's with their respective layouts, carbies etc AFAIK.
#9 _sstorana_
_sstorana_
Posted 27 February 2014 - 10:27 AM
The heater hoses are the same for V8 LH and LX (Pre 27A). Later LX (post 27A) are different.
Mick
#10 arrimar
arrimar
  • 3,134 posts
Posted 27 February 2014 - 11:27 AM
Heater hoses for LH 253-308 excl L34
#11 _LHSL308_
_LHSL308_
Posted 27 February 2014 - 12:19 PM
Yuk thats a terrible set up.
#12 hanra
  • 10,936 posts
Posted 27 February 2014 - 02:26 PM
These were taken in the early stages before I had purchased the correct ignition coil and hose clamps.
B731A93C-8A74-4042-A97D-B08A6277093C_zps
63657AFF-8242-4DA1-AEEE-8B0CA146470E_zps
CBC8DBB0-5473-4710-80F8-444DD76E19C9_zps
C7542F43-C6B9-4F08-A925-ED0F707E6620_zps
6EEFF1E7-6CFC-4DD5-B7AD-A0AC115E335C_zps
Edited by hanra, 27 February 2014 - 02:27 PM.
#13 _LHSL308_
_LHSL308_
Posted 27 February 2014 - 04:52 PM
Yeah I didnt have the outlet on the rear of the manifold so I couldnt set it up that way, not to mention I have 2 small outlets on my thermostat housing.
I much prefer the LX set up as it looks a bit neater but I understand why some would want the LH setup for originality.
So I guess it comes down to what setup the OP has got?
Chuck up a photo of your engine setup Sammy?
Edited by LHSL308, 27 February 2014 - 04:55 PM.
#14 TerrA LX
Posted 27 February 2014 - 06:04 PM
LX has the thermostat bypass which should help with cavitation.
