Painting a master cylinder
10 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 02 March 2014 - 10:50 PM
I've sandblasted my master cylinder and want to paint it black, will 2 Pac peel/react to brakefluid.
Also can something be applied to inside where the fluid lives to protect from rust?
Marty
#2 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,671 posts
  • Car:LJ GTR
Posted 02 March 2014 - 11:39 PM
Again calliper paint is brake fluid resistant to a point so should last longer than most paints, Good idea to etch prime also and be careful when bleeding brakes etc. by placing clean rag over & around master, or better still get one of those 1 man brake bleeder tools......
#3 S pack
  • 15,722 posts
Posted 03 March 2014 - 08:04 AM
Also wash off any brake fluid spillages from any paintwork with clean water immediately.
#4 _mikecatts_
_mikecatts_
Posted 03 March 2014 - 08:14 AM
por 15.
#5 hanra
  • 10,969 posts
Posted 03 March 2014 - 08:17 AM
I 2pac'd mine. Yes brake fluid will still hurt it but if it's wiped off with water ASAP then you should be fine.
E4E90CEB-503B-4FBD-9A03-AF34466B1A31_zps
F1DD7ED1-1C98-4F83-B160-0A6A15F8D272_zps
Edited by hanra, 03 March 2014 - 08:18 AM.
#6 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 03 March 2014 - 08:38 AM
Wouldnt put anything on the inside.
If it comes off could lead to catastrophic events.
Just clean it up.
If properly looked after further rust shouldnt be a problem.
#7 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 03 March 2014 - 12:55 PM
Back in the day I painted mine with fire engine red VHT from a spray can, possibly the flame resistant stuff that I had left over after painting the M21, came up a treat with the chrome lid.  Was years before it started to peel and only on the large bolt on the end there.
s
Edited by StephenSLR, 03 March 2014 - 12:55 PM.
#8 N/A-PWR
  • 9,637 posts
Posted 03 March 2014 - 02:00 PM
The Brake Fluid will stop it from Rusting Marty. Dave I
p.s. as long as you throw the Torana around, so the fluid is always washing
#9 dattoman
  • 16,487 posts
Posted 04 March 2014 - 12:10 AM
You could try some of this
http://www.eastwood....osol-13-oz.html
#10 _Bomber Watson_
Posted 04 March 2014 - 06:20 PM
If you blow a 2k epoxy primer over it then a polyurethane top coat you could soak it in brake fluid and it will give no frOcks.
#11 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 04 March 2014 - 06:42 PM
Thanks guys, I've 2k etched it and then I'll 2k top coat. The inside will be left bare.
Marty
