Hi Clint,
I've played with my exhaust a fair bit over the years, so here's some comments that may help.... (mine's a 450HP Chev with Tri-Y's)..
Started with a full twin 2.5" system, one muffler per side (straight through with expansion chamber style).... a little loud, and a bit "thong-slappy".
Next up, fitted two 10" resonators (hotdogs) - one per side, before the mufflers. This definitely toned the note down a touch. I've heard as a general rule of thumb resonators will bring the volume down around 3dB. I also believe they are more effective when installed further down the system (ie. as far back as possible).
Finally, I fitted an x-pipe up front. This toned the note a little more again, removed a lot of the thong slap, and made it sound much nicer. Other mates of mine have had similar comments with the x-pipes toning the note a touch - so I'm guessing they could be worth another dB or two (or possibly more). It's hard to say without doing formal testing.
My system has flanges everywhere, so when I want the car to be more angry, I can quickly remove the tailpipes and run dumpers before the diff. The difference is fantastic. This also allows flexibility to play with different tail-pipes for low cost. I remember a decade or so back, I had a 2nd set of tailpipes made up.... tiny little 2" ones with hot dogs in them, which fitted either side of the drop-tank (I needed to clear an EPA or something from memory) and worked like a treat. Small tailpipes, and hotdogs as far back as possible are very effective at pulling down the dB.
Another mate of mine replaced his straight through mufflers for triple flows, and we actually did test that back to back with no other changes - they removed several dB, but I can't recall the exact figure.
Also - try to install the biggest (physical) mufflers that you can fit. The Hooker aero-chambers that you mentioned are very popular, but they're definitely not a quiet street muffler.
It's all just about trying different things to achieve what you need. Just do yourself a favour and use flanges!!
Edited by LXCHEV, 29 April 2014 - 09:43 PM.
