Which of these distributor for 73 GTR
27 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 May 2014 - 06:58 PM
Hi all, I have three dizzys in my possession. Two are Bosch and similar and one is Lucas. Would one of these suit my build? Date stamps don't matter, just looks. I'll get it refurbished and re curved if that is the thing to do?
Marty
Edited by sibhs, 05 May 2014 - 06:59 PM.
#2 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 05 May 2014 - 07:30 PM
Hi
Bosch - 2820111
Bazza
#3 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 05 May 2014 - 08:05 PM
Joseph Lucas was not known as the "Prince of Darkness" for nothing. Lucas = crap English reliability. Had Lucas electrics in a HZ V8 coz thats what the General fitted to them back then, piece by piece changed to Bosch because of problems, this is your chance to start of with the right stuff.
#4 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 08 May 2014 - 06:11 PM
Ok Bosch it is. The two I have don't have the 2820111. Are any of these suitable? ugaze7a8.jpgba5yte5u.jpg
#5 Ice
  • 15,200 posts
Posted 08 May 2014 - 06:46 PM
Throw all 3 in the bin and use a electronic one
oh hang on its not factory i forgot
Mr anal
#6 N/A-PWR
  • 9,637 posts
Posted 08 May 2014 - 06:54 PM
Points Dizzy's are still good, just need to change the points often. Dave I
but I will use a Blue Motor Electronic one this time round
#7 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 08 May 2014 - 07:42 PM
Hi
Same dizzy twice?  It's/they are from a VB Commodore
Bazza
#8 frash da bucket
frash da bucket
  • 1,890 posts
Posted 08 May 2014 - 07:48 PM
Hi Dave,
I have points in mine and check the gap every 3 months.
The last set I had in it lasted for 7 years, and the mileage I do every year is 2,500 miles and very well maintained.
Regards John.
#9 N/A-PWR
  • 9,637 posts
Posted 08 May 2014 - 07:55 PM
Wow John, and thank's Bazza,
well I was using a GT40 Coil and reeving at 7000/7800rpm every time possible,
till the motor does a big end in, and the points always grew a pyramid, and I would file them down till the points were stuffed.
So, it is great to see the other side of the story John, thank's. Dave I
20 motors later hey, still the same
#10 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 08 May 2014 - 10:35 PM
Hi
Bazza
So it is! Not paying attention when taking photo. This 2820111 dizzy you mention, is it only found on GTR or lots of models. (Will it be easy to find or hard)?
#11 N/A-PWR
  • 9,637 posts
Posted 08 May 2014 - 10:40 PM
said HT on, on the Net, could be wrong. Dave I
https://www.google.c...iw=1455&bih=727
#12 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 08 May 2014 - 11:12 PM
Hi
2820111 was standard for all 173 (2850) and 202 (3300) engines including LH,  LX and  HQs etc.
This does not include LJ XU-1s
Bazza
#13 N/A-PWR
  • 9,637 posts
Posted 10 May 2014 - 03:15 PM
Any Luck Marty on your Finds
#14 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 May 2014 - 07:19 PM
No luck yet. Haven't looked hard so it will be luck if I come across one. Here's a pic of the other one that I was going to photograph. 9y9arajy.jpg. What would happen if I used one of mine? Surely it looks the same and will run the same, just different number. Then I can get this engine cranked up sooner, then just keep an eye out for the real deal.
#15 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 11 May 2014 - 07:57 AM
That dizzy will be ok to fit in your engine. If you are running a different cam it may pay to get it re-graphed at some stage.
#16 N/A-PWR
  • 9,637 posts
Posted 11 May 2014 - 11:01 AM
I have a GMH 2820111 if you get stuck Marty:-
Attached File  IMG_5157.JPG   32.05K   2 downloads
Attached File  IMG_5156.JPG   46.21K   5 downloads
Attached File  IMG_5155.JPG   86.98K   5 downloads
this one has the Electronic Ignition Module installed,
but I dare say, you can screw out and screw in the points one, same screws there. Dave I
#17 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 11 May 2014 - 11:44 AM
Hi
Check out this one
Bazza
http://tinyurl.com/kspvd67
#18 N/A-PWR
  • 9,637 posts
Posted 11 May 2014 - 11:58 AM
Good Starting Price Bazza,
Pay no more than $150 total hey. Dave I
Hi
Check out this one
Edited by TORYPOWER, 11 May 2014 - 11:58 AM.
#19 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 11 May 2014 - 07:12 PM
Thanks for the offer Dave, I may take you up on that.
That polished one, can't see the number but also says to totally rebuilt but condenser wire still looks old.
#20 N/A-PWR
  • 9,637 posts
Posted 11 May 2014 - 07:18 PM
if you look at another picture there Marty,
I could see the 2820111. Dave I
also, when they say refurbished, do they mean, the linkages have been fixed too
#21 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 11 May 2014 - 07:27 PM
Thanks Dave, didn't see the other pics. Doh!
#22 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 11 May 2014 - 11:58 PM
Stripped and cleaned mine up. Plan is to fit a metal gear and new condenser, points and rotor. I've checked vacuum pot and that seems to hold vacuum. Anything else I need to look out for? Also what lube do I use on moving parts and the felt around shaft? Marty
#23 frash da bucket
frash da bucket
  • 1,890 posts
Posted 12 May 2014 - 12:15 AM
Hi Marty,
When you checked the vacuum did you see the vacuum plate thats holding points is moving from left to right?
It might be a good idea to clean it and put some machine oil between each plate so it moves ok.
I have seen a lot over the years that have seized up.
Regards John.
#24 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 12 May 2014 - 12:20 AM
Whoops forgot pics. Thanks John, yes, checking movement on plates and weights etc. machine oil sounds good to me. a6asy6e9.jpguqu7yqu2.jpg2e3yrutu.jpg
Edited by sibhs, 12 May 2014 - 12:23 AM.
#25 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 12 May 2014 - 09:40 PM
Hey all, slight thread steal, but while all you cluey blokes are around...
I have a bosch 6 cyl dizzy here but no GM part number on it, twin point, metal gear, part number 9230 062 656. Any ideas?
