308 GLIMER Drive KIT
Show me yours
7 replies to this topic
#1 _76S.L.R_
_76S.L.R_
Posted 08 May 2014 - 07:10 PM
Ive allways wanted to install one of the GLIMER BELT DRIVE KITS onto the LX and am again looking at these and how easy they are to set up ( correctly). Theres some on ebay for $150 ( HI Energy) has anyone here used these ones??.
Just wondering how you guys set you your Alternator Brackets?, because my stock set up runs the Belt Very close to the Alternator bracket as it is. If someone has pics of their set up I'd really appreciate it
Im wondering if theres enough room between the AU Fans and the Water Pump
Edited by 76S.L.R, 08 May 2014 - 07:13 PM.
#2 N/A-PWR
  • 9,630 posts
Posted 08 May 2014 - 07:31 PM
Hi Scott,
Jacob, has got his going, and he will be here soon,
but in my opinion, the friction will cost you some economy.
But you did say you have a standard engine, and it will make your motor look Powerful. Dave I
need the belt driving a booster
#3 _Tony.p2_
_Tony.p2_
Posted 08 May 2014 - 07:44 PM
Hi Scott
This Gilmer Belt Drive was already on the car when I got so Icant tell you much about fitting it.Hope the pic helps.
#4 _76S.L.R_
_76S.L.R_
Posted 08 May 2014 - 08:27 PM
Been doing some more research on here and elsewhwere and most folk are saying  pay the extra and buy the DIECREST Kits, sounds like they are real pain to line it all up properly and if you don't then you are sure to have problems.
The other thing that concerns me is wearing out the Water Pump and Alternator Bearing quickly by running one of these?,is there any truth to this?,ive just allways wanted one for the Fantastic Noise they make..LOL
From the end of my Water Pump Pulley to the AU Fans I only have 50mm
Edited by 76S.L.R, 08 May 2014 - 08:30 PM.
#5 Shiney005
  • 9,470 posts
  • Car:Toyota Mirai
Posted 08 May 2014 - 08:50 PM
Surely, using a belt with teeth would mean you could run less tension, and therefore less stress on the bearings.
#6 _Bomber Watson_
Posted 08 May 2014 - 08:57 PM
Nope.
#7 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 08 May 2014 - 11:31 PM
Attached File  DSC00898.jpg   253.9K   3 downloads
Engine has been running this gilmer for 20years+ without issue
But seriously, how many people would buy one of these if they fitted a square Torana?
http://reidspeed.com...-and-powersteer
#8 76lxhatch
  • 7,195 posts
Posted 09 May 2014 - 07:30 AM
^ Everyone seems to love those one piece serpentine belt setups, personally I think they are ugly and would rather have multiple belts...
Yes they can run quite loose, but they don't make much noise like that so people tend to over-tighten them which creates significantly more load than a properly tensioned V belt
