Posted 11 May 2014 - 09:30 PM
Posted 11 May 2014 - 09:39 PM
Bosch is better. Probably harder to get parts for the Lucas than the Bosch anyway.
Posted 11 May 2014 - 09:44 PM
if you have a tighter motor or more compression, a Starter Motor with a bigger diameter has more torque, and uses more power to do the job
Posted 11 May 2014 - 10:05 PM
Hi
According to the parts catalogue, Bosch was the only starter specified for the the standard 202. It is part number 2815873 and was used on 202s right through to the LX.
Bazza
Posted 11 May 2014 - 10:29 PM
Posted 11 May 2014 - 10:33 PM
Posted 11 May 2014 - 11:54 PM
Posted 12 May 2014 - 12:08 AM
You might struggle to fit the big Bosch if you have after market extractors fitted.
Posted 12 May 2014 - 12:10 AM
Posted 12 May 2014 - 12:13 AM
Did you read the bit that said "IF" yoo Geno yoo!
