Posted 06 June 2014 - 07:03 PM
Posted 06 June 2014 - 07:17 PM
The top one in the first pick is correct, but the other one looks like it would work better.
Posted 06 June 2014 - 07:32 PM
Marty the thinner one looks to be in better condition and I,d probably use this one , the fins on the fatter one are a bit shabby .
Although looking at the quality of your build car which is pretty good , think about a new one , I bought one through the local radiator guy and wasn,t expensive.
Those things make a mess of your interior when they give up.
Posted 06 June 2014 - 07:41 PM
Also if you want to use either of them get them pressure tested first.There's a lot of hard ache in changing a core over once in the car.
Posted 06 June 2014 - 07:49 PM
Posted 06 June 2014 - 07:59 PM
Marty I think Shaun is saying that there are new ones out there that will fit into our heater boxes.
Posted 06 June 2014 - 08:02 PM
Posted 06 June 2014 - 09:01 PM
Marty, top one is LC, bottom one is LJ/TA, however I don't know if the tank change was made during LC or LJ production.
The core in your LJ one is a recore. The LJ core was basically same design as the LC core.
I have an original LJ heater core assy with the date code 83S if you need a pic.
Posted 06 June 2014 - 10:02 PM
Marty it was a natra agent radiator shop , although it was 5 years ago , but they still produced them the same as original as natra was the original supplier , memory was about 100 dollars each new so I bought 2 .
just make a phone call to see if they still supply , natra rad shop in most major towns .
Posted 06 June 2014 - 10:15 PM
Now known as Natrad , found there website with a location directory , quite a few shops in perth , you may get lucky if no longer made with one shop having unused old stock
Posted 07 June 2014 - 09:14 AM
Correction to my previous post. The date code on my old core is B3S so Feb 1973. Most likely the original (leaky) core from my 4/73.
