Coffee pot question
14 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 June 2014 - 02:29 PM
I had this part bagged as "under coffee pot" but when assembling It doesn't make sense. Please help. Cheers. Marty5e9u8yha.jpg
#2 _judgelj_
_judgelj_
Posted 10 June 2014 - 02:51 PM
inside of the upper steering column case?
#3 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 June 2014 - 02:57 PM
I thought here but nothing holds it in position. It needs something here to hold it. ju7egene.jpg
#4 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 June 2014 - 03:10 PM
This just fell out the bottom of column while I was fitting lock. Where's it from?matusaru.jpg
#5 S pack
  • 15,722 posts
Posted 10 June 2014 - 03:16 PM
Is this a 3 on the tree column?
Can't remember seeing one of those pins before, maybe from the ignition barrel? Actually looks like a needle roller from a gearbox input shaft.
#6 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 June 2014 - 03:20 PM
Bits from a three and a four to make a four. I think it's out of the back of key barrel. None genuine rares one.
#7 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 June 2014 - 03:23 PM
What are your thoughts on the plastic sheild Dave?
#8 S pack
  • 15,722 posts
Posted 10 June 2014 - 03:56 PM
You don't need the gear change tube nylon bearing in a console shift column.
#9 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 June 2014 - 03:58 PM
Awesome, thanks Dave. :-)
#10 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 June 2014 - 05:07 PM
All done. Thanks all. Except that brass pin. I'm sure I'll find out one way or another. uhegaher.jpgbeganyhu.jpg
#11 UCSLE
UCSLE
  • 710 posts
  • Name:troy
  • Car:Goggomobil
Posted 10 June 2014 - 09:09 PM
The brass pin looks about the right size for the spring loaded pin that the horn uses , never had one out so I couldn't tell you for certain .
#12 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 08 January 2017 - 10:58 PM
I'm sure that pin has come out of the lock barrel.  Still works but the key-hole-surround tends to come away from column and I presume the missing pin is the culprit.
Marty
#13 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 08 January 2017 - 11:27 PM
Yeah, looks like the spring loaded pin for the horn.
#14 S pack
  • 15,722 posts
Posted 08 January 2017 - 11:48 PM
Marty
Says in the LJ ignition lock cylinder tumbler installation instructions to (step 6) " Depress spring loaded detent pin on opposite side to anti theft ring tab, then ease key entrance end of lock cylinder further round in a counter clockwise direction, disengaging lock cylinder assembly from sleeve"
Horn contact pin is made of sintered bronze and has a wire attached to the end of it.
#15 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 January 2017 - 10:02 AM
Thanks Dave and Tony.
Definitely not the horn one.
Next time the barrel comes out I'll fix it.
Ta
Marty
