Tips and tricks. Interior
11 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 June 2014 - 04:47 PM
Advice required on these questions.
The extra vinyl that came with my pre-made door cards (for door tops etc) is thicker than original. Is the thinner black long grain easily available?
The plastic plugs that fit in doors for metal clips on card to sit in, they don't fit in the holes of body for rear cards. What's the go here?
I was going to use contact adhesive, apply to body and vinyl, let it go tacky then stick vinyl down while smoothing out. Trim off excess. Sound right?
New vinyl was folded and has a crease, how can I remove?
Marty
Edited by sibhs, 17 June 2014 - 04:49 PM.
#2 Statler
  • 6,314 posts
Posted 17 June 2014 - 05:00 PM
Try pinching the plugs when fitting them. The should be the same on all 4 doors.
Set the vynal in the correct spot * mark the door lock button hole. Use a wad punch to put a hole in the trim before fitting. That way it gives you a guidance point when fitting the trim.
#3 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 June 2014 - 05:07 PM
Thanks Col, The door trim holes are larger than the rear body holes. My guess is don't use plastic plugs on rear cards.  This is a two door LJ by the way. Concerned that once they go in then won't come out without plastic plug.
#4 S pack
  • 15,722 posts
Posted 17 June 2014 - 05:33 PM
Marty, from memory there are no plastic plugs used for the 2dr rear trims.
Can you use your original vinyl garnishes as templates to cut out the new ones?
Stretch the creases out as you glue the vinyl on??
#5 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 17 June 2014 - 05:52 PM
Hi Dave, Just been thinking why plastic plugs for front and not back?  I reckon its to stop water rusting the clips. There is no plastic splash guard behind rear cards because water doesn't run down there, so plugs not required? What do reckon to that theory?
Yes, I'm using old garnishes for rough template. Just not sure about using this thicker vinyl? If thinner is available i will get some.
Marty
#6 _LONA-CK_
_LONA-CK_
Posted 18 June 2014 - 07:28 AM
sibhs
spot-on
cheers gong
#7 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 18 June 2014 - 12:08 PM
Can you iron the creases out of the vinyl before gluing on?
#8 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 18 June 2014 - 08:06 PM
Not sure? Maybe someone here knows? Might have a play with the iron, start by doing the cloth side.
#9 Ice
  • 15,200 posts
Posted 18 June 2014 - 10:02 PM
Maybe try a bit of heat with a hairdryer Marty for the creases
#10 S pack
  • 15,722 posts
Posted 19 June 2014 - 12:47 AM
Or lay the vinyl out flat in the sun for a while???
#11 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 20 June 2014 - 10:37 AM
The Auto trimmers on here aren't sharing their knowledge.  C'mon guys, help me out. :-)
How to remove creases from vinyl?
Can you easily still get the thin long grain black material for door tops etc?
Thanks to those that have tried to help.
Marty
Edited by sibhs, 20 June 2014 - 10:38 AM.
#12 S pack
  • 15,722 posts
Posted 20 June 2014 - 10:58 AM
Marty, I believe you can't get the exact same vinyl as the original however this headliner material is similar. SMS Fabrics here in Brissy used to sell it but I think they have closed down.
