K Frame outrigger bushes
10 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 22 June 2014 - 03:42 PM
Hi Guys. As pictured is how I thought the bushes should go in a LJ.
Speaking with other people and they suggest the same. Measure the car and that looks correct for best fit.
BUT
Look in the book and it shows this?
Thoughts please.
Marty
Edited by sibhs, 22 June 2014 - 03:44 PM.
#2 S pack
  • 15,722 posts
Posted 22 June 2014 - 03:46 PM
Marty, the diagram in the parts book is correct for fitment of the LC/LJ rear brace bush.
#3 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 June 2014 - 09:57 AM
Hi Dave,
On what grounds is the book correct?  It has been wrong before.
It doesn't make sense having metal to metal contact at that point.  I even found my picture before restoration and it shows the bush the other way.
Attached File  IMG_1867.jpg   62.66K   19 downloads
Can anyone else help me on my quest to defy the GMH manual.
Marty
#4 S pack
  • 15,722 posts
Posted 23 June 2014 - 10:25 AM
Please have a read Marty. Note post #16
http://www.gmh-toran...outrigger-bush/
#5 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 June 2014 - 04:25 PM
That's interesting reading Dave, also shows a lot of conjecture regarding these bushes. There must be guys here who race these cars, put them under extreme pressure and have tried both ways. My guess is, it makes no difference. Thanks, Marty.
#6 S pack
  • 15,722 posts
Posted 23 June 2014 - 05:00 PM
Whichever way you fit them is entirely up to you Marty. Just trying to point you in the right direction for correct fitment per GMH advice.
You know how lots of these Torana's suffer stress cracks in the braces where they attach to the crossmember? I can only say my original crossmember suffered those same cracks and had the bushes installed with the large head against the rail.
The NOS crossmember I fitted back in the late 80's with the brace bushes installed the correct way as per the GMH Dealer Service Letter is so far free of any cracks.
Dave.
#7 IanC
IanC
  • 605 posts
  • Name:Ian
  • Car:LJ XU-1
Posted 18 March 2022 - 05:26 PM
BUT
Thoughts please.
Marty
Just doing mine now.  Mine were as you have shown Marty.  I'm not saying it's right. But it makes mare sense to me to be that way.  My bolt came from outside, with the nut on the inside.  The outside of the bolt hole has an unremovable steel washer. the inside of the K frame where the bolt ends has a steel washer to protect the rubber bush.  Not saying it can't go both ways. But generally if a washer is fixed to a section, that is where the head of the bolts would sit. And the threaded end would be fitted with washers and nut.  my way of thinking anyway.. ?
#8 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 30 July 2023 - 10:11 AM
Hi guys,
Old thread i know, but most relevant.
The bolt that goes through the k-frame out rigger bush and chassis rail. What length and thread is it meant to be.
My car has 4-inch long 7/16 unf bolts fitted with conelock nuts.(not quite long enough that a full nut screws entirely onto the bolt with a smidge of thread to show after tightened.
The LJ parts catalogue lists (marked it purple) a 4-1/2 inch unc bolt, closest thing to fit that area.
Cheers :)
Jaso
#9 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 30 July 2023 - 11:20 AM
Hi all, this has my answer. :) Time to go shopping for some.
https://www.gmh-tora...hl=+out +rigger
#10 73SUNBURSTEXYOUWON
73SUNBURSTEXYOUWON
  • 819 posts
  • Name:JASO
Posted 11 August 2023 - 04:00 PM
Hi all,
in the attached image - what build LC LJ cars is this washer item 6 applicable to?
and has any one got the p/n and sizing of it?
Cheers :)
Jaso
#11 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 11 August 2023 - 08:59 PM
Contact me tomorrow afternoon Jason, I'll pop to the shed & check, got a busy morning though.
