the other day i had the torry on the rollers to see what difference the new manifold makes..made no difference
but this time i watched the fuel pressure at cruise i had 7 psi which dropped to 3 psi at wot
so ive been thinking about an electric pump and where to put it coz there anit much room
directly above diff centre at floor angle bout 50-60 mm clearance
horizontal in the center about the same
passenger side bracket part of tank breather lines quite good clearance but a pain to route fuel lines
or drivers side where fuel line is but above top control arm about 50-60 mm clearance
Edited by Mint Julip, 22 June 2014 - 06:11 PM.
