* * * * * 1 votes
Widened LJ Grille
52 replies to this topic
#26 Potta
Posted 04 July 2014 - 11:27 PM
If you can mount them so the door attaches to the bit that was originally part of the bonnet and have them rotate back to reveal the headlight.
So normally the light points down if you get what I mean.
#27 MustardGTR
MustardGTR
  • 243 posts
  • Car:72 GTR, 73 GTR
Posted 05 July 2014 - 12:10 PM
Dave I, my 2 cents worth, but I think the 68 RS Camaro had it right. i.e. the light covers hinge inwards and towards the center behind the main grill.
Either way whatever you come up with it's going to look great!
#28 Ice
  • 15,204 posts
Posted 05 July 2014 - 12:20 PM
I wouldnt worry about it Dave just get a pair of headlights with brighter globes wouldnt bother goin to all that trouble unless you goin to be doing a lot of night driving
there will be plenty of light coming thru the grill
#29 N/A-PWR
  • 9,639 posts
Posted 05 July 2014 - 12:44 PM
Very Good Alex,
That's the way to do it, may have to make the levers longer to suit, or have sliding doors.
http://www.youtube.c...h?v=M8gcoWaW0xM
http://www.youtube.c...h?v=cSZmYKHU0s4
worth a try Gene too.
#30 N/A-PWR
  • 9,639 posts
Posted 08 July 2014 - 10:50 AM
Here we go,
On the Steel Bumper Day, I picked up 2 off LJ Grille's,
One from Gene ( Centre ), and then one from Marty ( Outer's ), thank-you, you two.
I thought about it last night, and just cut up Marty's complete grille without chrome trims,
as you can see I have worked out a way to do this:-
Attached File  IMG_5517.JPG   24.27K   2 downloads
By, making the deeper parts of the grille be joined, we can have a modified outer curved piece to finish:-
Attached File  IMG_5521.JPG   31.73K   3 downloads
Attached File  IMG_5520.JPG   22.92K   3 downloads
As this is what will work, by putting the grille end pieces to the opposite ends of the main grille piece,
so having the vertical fins all pointing forward, and no front end Torana body modifications, and will still look good:-
Attached File  IMG_5524.JPG   133.65K   3 downloads
Attached File  IMG_5525.JPG   87.84K   3 downloads
Attached File  IMG_5526.JPG   49.81K   3 downloads
Attached File  IMG_5527.JPG   104.54K   2 downloads
Attached File  IMG_5528.JPG   96.01K   2 downloads
The Main grille weighs 2 pound, 14 ounces ( 1.3kg ):-
Attached File  IMG_5516.JPG   52.24K   2 downloads
Attached File  IMG_5522.JPG   42.32K   2 downloads
Attached File  IMG_5523.JPG   28.79K   2 downloads
and the two end pieces will have some extra weight removed, are One pound, 14 ounces ( 850 grams ):-
Attached File  IMG_5529.JPG   51.7K   2 downloads
Next update pending.
#31 N/A-PWR
  • 9,639 posts
Posted 08 July 2014 - 03:39 PM
As Requested, a Progression Update:-
Attached File  IMG_5531.JPG   49.76K   2 downloads
Attached File  IMG_5532.JPG   33.52K   2 downloads
Attached File  IMG_5533.JPG   39.85K   2 downloads
Attached File  IMG_5534.JPG   28.46K   2 downloads
Attached File  IMG_5535.JPG   42.03K   2 downloads
Attached File  IMG_5536.JPG   102.99K   2 downloads
Attached File  IMG_5537.JPG   26.95K   2 downloads
Attached File  IMG_5538.JPG   23.11K   2 downloads
Attached File  IMG_5539.JPG   98.67K   2 downloads
Attached File  IMG_5541.JPG   37.75K   2 downloads
Attached File  IMG_5542.JPG   46.87K   2 downloads
Attached File  IMG_5543.JPG   43.69K   2 downloads
Attached File  IMG_5544.JPG   89.3K   2 downloads
Attached File  IMG_5545.JPG   104.77K   2 downloads
Attached File  IMG_5546.JPG   47.43K   2 downloads
Attached File  IMG_5547.JPG   89.07K   3 downloads
Attached File  IMG_5548.JPG   51.47K   5 downloads
Attached File  IMG_5549.JPG   47.91K   2 downloads
Attached File  IMG_5550.JPG   48.39K   2 downloads
Attached File  IMG_5551.JPG   34.34K   2 downloads
#32 Ice
  • 15,204 posts
Posted 08 July 2014 - 03:42 PM
If you need some more stainless trim pieces i might have some spare ones some where you can have
#33 N/A-PWR
  • 9,639 posts
Posted 08 July 2014 - 03:47 PM
Attached File  IMG_5552.JPG   35.71K   2 downloads
Attached File  IMG_5553.JPG   40.34K   3 downloads
Attached File  IMG_5554.JPG   38.22K   2 downloads
Attached File  IMG_5555.JPG   33.06K   2 downloads
Attached File  IMG_5556.JPG   42.83K   2 downloads
Attached File  IMG_5557.JPG   100.35K   2 downloads
Attached File  IMG_5558.JPG   52.55K   2 downloads
Attached File  IMG_5559.JPG   54K   2 downloads
Attached File  IMG_5563.JPG   53.45K   2 downloads
Attached File  IMG_5564.JPG   31.73K   2 downloads
Attached File  IMG_5565.JPG   25.72K   2 downloads
and now weigh's, 4 pound, 4 ounces ( 1.9kg ):-
Attached File  IMG_5562.JPG   59.41K   2 downloads
More later
and that would be great Gene, as the RAT Grille needs them.
#34 _LS1 Taxi_
_LS1 Taxi_
Posted 08 July 2014 - 03:48 PM
I like how you've thought it through and what you've there Dave I and I LOVE the concept but I don't think that it will look like the 69 Rat as per the drawing....
Attached File  rat.jpg   26.97K   2 downloads
The grill isn't supposed to kick back out in the rat.  I think it would look better if it was straight as per the picture because then it would be following the front profile of the nose cone.
Keep the updates coming.  Where is the build thread?  This is a build!  :furious:
#35 N/A-PWR
  • 9,639 posts
Posted 08 July 2014 - 03:55 PM
Hey Daz,
All good, as this is part of the Big Picture, as each Part has it's own thread too to keep subjects separated.
The Links of the others Parts will be combined into the Main Build Thread coming up.
So all I do now is darken the insides and will look good from the distance.
I know what you mean though, would look better as Pictured, but I will try this way first and see.
We can always create the parallel way, as I just need to modify the Torana front end to suit the deep grille ends, hmm.
Edited by GASPOWER, 08 July 2014 - 04:09 PM.
#36 Ice
  • 15,204 posts
Posted 08 July 2014 - 03:57 PM
Paint the whole grill black and put the stainless on un polished for that rat look
#37 N/A-PWR
  • 9,639 posts
Posted 08 July 2014 - 04:29 PM
OK, just sat the Grille in place for all to see if this way is no good,
other wise chop, chop:-
Attached File  IMG_5566.JPG   45.15K   2 downloads
#38 _judgelj_
_judgelj_
Posted 08 July 2014 - 06:51 PM
Nice idea. Reminds me of the camaro with the full grill. Though im not a fan of the front spoiler.
No pop up lights though!! Make doors or just shine through the fins. Who needs to drive at night?
#39 Potta
Posted 08 July 2014 - 11:14 PM
Lookin good Dave
#40 Ice
  • 15,204 posts
Posted 08 July 2014 - 11:30 PM
Looks almost factory
#41 N/A-PWR
  • 9,639 posts
Posted 08 July 2014 - 11:31 PM
Excellent Jacob and Craig,
Yep, just need to see where we are at, and move forward.
he he Gene
#42 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 08 July 2014 - 11:38 PM
Looking good Dave, i didnt really get what you were trying to do until the last couple of pictures
#43 N/A-PWR
  • 9,639 posts
Posted 08 July 2014 - 11:42 PM
No worries Stinga, just thought to try the easy stuff first.  :sucker:
got some black can paint to darken the area to check out tomorrow
Edited by GASPOWER, 08 July 2014 - 11:53 PM.
#44 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 08 July 2014 - 11:57 PM
Can you post a pic of it from more of an angle from the side?
#45 N/A-PWR
  • 9,639 posts
Posted 09 July 2014 - 12:11 AM
Do tomorrow Ian,
#46 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 July 2014 - 12:15 AM
First few pics I thought that ain't working, but now I see it Dave. Looking good. Keek going Dave. I reckon this could be a car made by donated parts from members. Great way to use our spare parts that aren't up to show standard. I'm sure I have bits of stainless trim for grill you can have too.
#47 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 09 July 2014 - 12:17 AM
Do tomorrow Ian,
Cheers, Dave. I just want to see how it looks when you can see the angles in the grill. It almost looks flat in the front on shot.
Nice work though.
#48 MustardGTR
MustardGTR
  • 243 posts
Posted 09 July 2014 - 11:01 AM
Dave I, Great work!.
If not already considered would it be worth trimming a pair of returns cut from the ends of each grill and adding them the both ends of the widened grill. This would finish of the trim line around the perimeter.
#49 N/A-PWR
  • 9,639 posts
Posted 09 July 2014 - 11:18 AM
Ah yes Aleks,
I got two Full depth Returns from the centre LJ Grille,
but did not want to shorten the depth, unless the shortened one ATM looks good enough,
other wise, I will be going down the path of making a parallel section for each end of the RAT Grille,
which in any case will be going down a similar path as 'The Gong' is - An Alloy Set.
so I suppose, it wouldn't matter if I did shorten the depth then, good thinking Mate.
Edited by GASPOWER, 09 July 2014 - 11:19 AM.
#50 N/A-PWR
  • 9,639 posts
Posted 09 July 2014 - 11:51 AM
Cheers, Dave.
Here you go Ian,
Bit of a Black touch-up, and end return's:-
Attached File  IMG_5567.JPG   97.38K   1 downloads
Attached File  IMG_5568.JPG   83.98K   2 downloads
