New door handle springs
4 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 30 June 2014 - 09:43 PM
Hi guys,
I've got a couple of the internal door handle opening mechanisms, both drives side broken springs. (the ones that your internal door handle clips too)
Does anyone make these, cause if they don't I reckon I can make and fit new springs.
Problem number 1.  Where can I buy spring wire about 2.3mm diameter?
I've search and rung around and found nothing.
Anyone got some leads I can try?
Marty
#2 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 30 June 2014 - 10:21 PM
Googled and came up with weld wire. Checked my leftover, 2.4mm. Bent some up and quick test. This could actually work. Version two to come. ynu7aqu4.jpgjehypade.jpgasumesy3.jpg
#3 Ice
  • 15,200 posts
Posted 30 June 2014 - 10:25 PM
Not bad for a weekend warrior
#4 N/A-PWR
  • 9,637 posts
Posted 30 June 2014 - 11:53 PM
Stainless Steel / Wire has spring steel property's too, if that helps, good thinking.
#5 torana?
torana?
  • 95 posts
Posted 01 July 2014 - 09:38 AM
you can also buy piano wire that you can make springs from, some hobby stores sell it.
Edited by torana?, 01 July 2014 - 09:45 AM.
