Picture of LJ GTR harness plug
15 replies to this topic
#1 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 04 July 2014 - 06:13 PM
Hi guys, Can some post a pic of this harness plug for an LJ GTR or XU-1. It's the one the interior light and rear harness join to. There should be a difference from this 'S' version. Ta. Marty3aqyzyme.jpg
Edited by sibhs, 04 July 2014 - 06:13 PM.
#2 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 July 2014 - 10:57 AM
This is a great little task for this week-end.  Only for the guys who have the harness out of car or hanging down.
Marty
#3 Ice
  • 15,193 posts
Posted 05 July 2014 - 11:52 AM
I will try and get you a pic today Marty one of my mates is out of the car
#4 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 05 July 2014 - 12:21 PM
Thanks Gene, can always rely on you. (Thumbs-up)
#5 MustardGTR
MustardGTR
  • 242 posts
  • Car:72 GTR, 73 GTR
Posted 06 July 2014 - 02:33 PM
Marty, Photo of the harness/ wiring from my Adelaide 5/73 GTR.
#6 Ice
  • 15,193 posts
Posted 06 July 2014 - 04:56 PM
Beat me to it
#7 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 06 July 2014 - 10:20 PM
Thanks Aleks, not what I was expecting.
Do you have a boot light?  Trying to see how that joins in at that point.
Marty
#8 S pack
  • 15,691 posts
Posted 07 July 2014 - 01:02 AM
Marty, the boot light plugs into the tail light wiring harness tucked up inside the right hand rear qtr panel.
#9 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 07 July 2014 - 09:11 AM
Hi Dave, the wiring diagram indicates a seperate orange wire from this harness to globe. 's' rear harnes has no constant power feed.
#10 S pack
  • 15,691 posts
Posted 07 July 2014 - 09:33 AM
Sorry Marty.
When the boot lamp is fitted as an accessory it is connected into the rear park lamp circuit. When factory fitted it connects to the interior light and brake light power circuit.
Just thought in your application connection into the park lamp circuit, as in an accessory installation, would be easier.
Dave.
#11 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 07 July 2014 - 10:07 AM
When have I taken the easy way Dave?  :-)
#12 MustardGTR
MustardGTR
  • 242 posts
Posted 07 July 2014 - 09:12 PM
Marty, how correct do you want to be with the harness? Your harness is circa 72 which appear different to that of a 73 Torana S.
Here is a photo of a late 73 S harness. Note the orange wire(s) are present in the "J"  terminal of the main body harness connector. All you would need to do in this case is run a orange wire from the "J" terminal of the rear body harness connector (currently missing) back to a boot light, etc
Possibly two, maybe three options here....................................
Option A - Acquire a 73 GTR harness
Option B - Marty's Repo - Someone may have unraveled all the the wiring in the main harness and can advise on how/ where the orange wire(s) are connected i.e intent of original topic.
Option C - Simple Fix - it is possible to "adjust" the wiring so that it looks correct from the outside and has all the functionality of a GTR. Downside is you may not be able to live with the thought that it's a work-around. LOL
#13 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 08 July 2014 - 12:07 AM
Great pics Alecs, I think option B.  I've got more research to do before this happens.
Marty
#14 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 July 2014 - 12:31 AM
Worked it out, with your help and others. This part of diagram showed the boot orange wire joining a brown wire that is connected to light switch. 8y4eqevy.jpg with the word accessory in the brown wire. <br />This is a diagram for two different cars. One with orange all the way to front harness is factory wired. Brown wire from globe to rear harnes indicates it was fitted on as accessory.
#15 MustardGTR
MustardGTR
  • 242 posts
Posted 09 July 2014 - 11:55 AM
That diagram is not correct for a 73 car, particularly how the orange wire enters/ exits the Body Wiring Harness Connector. I know your diagram comes up in this forum  but what is the source and what model is it for i.e LC?.
The 73's are more like a LH (diagram below). You only need wire into the "J" terminal of the connector i.e. 2 x orange "in" to a common spade (you can see this in photo above) and 1 x orange "out" and run back to boot light.
And goes without saying you don't need to wire in the "accessory" option.
#16 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 July 2014 - 10:01 PM
Hi Aleks, the harness is a 72 s but making it a 73 GTR. Therefore the orange wire from globe to harness letter J is the go. Cheers. Marty
