Hi, picked up a set of triple su's this weekend.
I have attached a photo, can someone please have a look and see if anything sticks out that is wrong or missing on them.
I have trolled the net but can't find many decent photos of LJ's with SU's, mainly xu1's with strombergs.
I got these to replace my twin downdraught strombergs.
Questions:
1/ Is it worth kitting and fitting these or should I just rebuild what I have?
2/ Do I have to change the throttle from linkage to cable?
3/ I can't see where to put the choke on them?
4/ Do I need to move anything, i.e. the battery?
I really want triples, (mainly for the look!), but it is a relatively mild 202, and if it is going to be $$$, then maybe I should fix my daughters wisdom teeth instead.
Any comments or tips greatly appreciated (not about the daughter)
The triples look nice, actually. They could be a lot worse (visually).
1. Honestly, probably not worth it. Unless the butterfly shafts are in good nic and not worn. If that's a case, re kit them, otherwise you will be up for re bushing. That will run you around 350 per carb including the re kit, at least that's what it cost me. The problem is that a lot of them are worn and tend to be a bit leaky, hence the ignorant feedback towards them.
2. Depends, what throttle setup do you currently have?
3. Choke should be near the throttle leaver or opposite side (cant picture it) and will lower the jet (underneath) when you operate it. But you don't really need it, i've never used a choke.
4. Not in an LJ, but would look a lot better with out it. It may perhaps limit what sort of air filter assembly you use.
Also, i can't tell what they are they have funny fuel pots. See if you can find any writing on them, should read like HS6 or something. Let us know.
If you check out the link under this post, go to the end of that build thread and there should be a shitload of photo's with my SU's in the LC. Feel free to PM me anytime if you need help. Im not far from werribee.
Edited by judgelj, 07 July 2014 - 02:46 PM.
