Bending Fuel bundy tube
44 replies to this topic
#1 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 08 July 2014 - 03:35 PM
Help required.
Bought some Bundy tube to make my fuel lines.
Can't get it to bend with-out kinking.  Kinks doing a less than 45 degree, kinks when crc applied, kinks when doing a bit at a time and moving the tube along.
Where am I going wrong??
Using Bosch steel bundy tube 5/8.
Pics to follow
#2 Ice
  • 15,221 posts
Posted 08 July 2014 - 03:45 PM
I would use alloy tubing my self for fuel line much easier to be bend
#3 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 08 July 2014 - 03:52 PM
Martin,not 5/8 it,s 5/16 bundy tube not alloy tube.cheers
ps xu1.com talk to brad
#4 S pack
  • 15,762 posts
Posted 08 July 2014 - 04:44 PM
How are you operating the bending tool??? It's either the bending tool, the tool operating the tool or tubing with a very thin wall.
#5 _judgelj_
_judgelj_
Posted 08 July 2014 - 06:00 PM
Maybe get it a little bit warm first?
I bent up brake lines no dramas using a pipe to press against.
#6 76lxhatch
  • 7,222 posts
Posted 08 July 2014 - 06:06 PM
Looks like the wrong tubing to me
#7 N/A-PWR
  • 9,644 posts
Posted 08 July 2014 - 06:14 PM
Marty,
You need to lock the tube to the bender,
so when you move the handle around the degree curve,
the tube cannot take the easy way out, in other words, move forward and kink.
At the entry, zero end, that is where the tube must stay.
I say this bender is only for copper say, and you need a clamping model, other wise, more force will snap this handle.
#8 N/A-PWR
  • 9,644 posts
Posted 08 July 2014 - 06:18 PM
Done heaps of 316 stainless bending for the Acid and Corrosion Industries
Use a Black Marker to show where the start of the measurement is, and you can also see creep
#9 dattoman
Posted 08 July 2014 - 07:04 PM
Told you that tubing was rubbish... thats why I use the stuff I lent you (3/16)
Bosch bought PBR and thats their offering... rubbish
Not sure I can get the same tubing in 5/16 though
But might be able to get something better
Some gentle heat might help... but makes things fiddly
#10 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 08 July 2014 - 07:52 PM
Thanks guys, I will try some of these ideas, was also told to fill with sand.
I'd like new tubing but may have to clean-up my old stuff if this fails.
My old long piece is blocked, compressed air Fail, metho and air gun - fail.  Need to try some flexible wire maybe to poke in there?
Let me know Datto.  Also how do you get that rib line on the end of fuel pipe?
So far spent $40 on tube and two fittings, and lots of time driving around.  Bit of a wasted day off really.
Marty
Edited by sibhs, 08 July 2014 - 07:53 PM.
#11 S pack
  • 15,762 posts
Posted 08 July 2014 - 08:02 PM
Marty,
Nothing intrinsically wrong those tube benders Dave. I've got one similar to Marty's and it bends 5/16", 1/4" and 3/16" bundy no problems at all.
I reckon it's the coiled tube that is the problem, thinner wall so it straightens out and bends easier by hand.
#12 _Bluejinx202_
_Bluejinx202_
Posted 08 July 2014 - 08:18 PM
Try using a bender designed for bigger tube like 1/2 benders.
#13 _judgelj_
_judgelj_
Posted 08 July 2014 - 09:00 PM
Or try slowly bending around a pole like a street sign or something? If you fill with sand i dare say you would have to keep the ends blocked. Maybe even tapped and bolted.
#14 _Bomber Watson_
Posted 08 July 2014 - 09:06 PM
Just buy better tubing.
I had no issues bending some 5/16" Bundy i got from summit years ago.
And the 3/8" alloy stuff i got from Summit not quiet as many years ago was an absolute dream to work with.
#15 _Viper_
_Viper_
Posted 08 July 2014 - 09:24 PM
Weird, We get the same looking tube from Coventry's and I just use a bender exactly like the one you have pictured and it bends quite well... Maybe its a different brand not sure...
Apparently Enzed sell straight sections that are much easier to bend tho.
#16 _victor_
_victor_
Posted 08 July 2014 - 10:47 PM
Try filling the tube with sand then bend. Block both ends
Victor
#17 _outer control_
_outer control_
Posted 08 July 2014 - 11:05 PM
Got some tube years ago all that was available shocking to bend and flare bought a length 3 weeks ago completely different soft and easy to work (shop around)
#18 dattoman
Posted 08 July 2014 - 11:31 PM
http://www.eastwood....content=1EM2510
#19 ls2lxhatch
  • 5,335 posts
Posted 09 July 2014 - 01:37 AM
Help required.
Is your tube 5/8 or 3/8, it looks like 3/8 in the pictures. I have a good quality bender for 3/8 tube you can try.
Edited by ls2lxhatch, 09 July 2014 - 01:39 AM.
#20 Bernie
Bernie
  • 301 posts
  • Car:2 lx Hatches and 3 lx 4 doors
Posted 09 July 2014 - 02:48 AM
Have you tried using some grease on the tube where you are bending it in the bender ? Using heat will make it easier to do but you run the risk of dis colouring your tube .Have you tried to Flare it yet ?Does it split ?
Bernie
#21 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 09 July 2014 - 02:51 AM
some heat it up with only accetalene so it dont get too hot.will look sooty but should
come off seen others to straighten the tube,get a block of wood and drill a hole through
it and pull it through it
#22 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 July 2014 - 10:07 AM
Flareing worked well. Sorry tube wasn't 5/8 it's 5/16. I won't try heat because of discoloration. I tried CRC but not grease. I'll fill it with sand blast sand and try that.
#23 MustardGTR
MustardGTR
  • 243 posts
  • Car:72 GTR, 73 GTR
Posted 09 July 2014 - 10:40 AM
Did you Double Flare the tube? And what flare tool did you use as I've never had much luck with the cheap and cheerful kits.
Also interested in knowing if the "rib line"at the end is doable?
#24 ls2lxhatch
  • 5,335 posts
Posted 09 July 2014 - 11:17 AM
Enzed Welshpool should be able to flare and/or bend the tube for you.
Mastercool have a tool that will make the GM fuel line and push connect flares on 5/16 and 3/8. I have one if you want to try it.
http://www.mastercoo...ring_tools.html
Earls make tubing beaders to suit 3/8, 1/2, 5/8, 3/4, 1, 1 1/4, 1 1/2, 1 3/4, 2 in. tube. They are sold separately or in a kit. Browns Radiators did have the kit.
http://www.summitrac...arts/ear-018erl
I also have a tube straightener which makes it easy to get a straight tube to start with.
Edited by ls2lxhatch, 09 July 2014 - 11:27 AM.
#25 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 09 July 2014 - 02:40 PM
I would have to agree with Dave (gaspower)
Make sure the trailing end is locked in place and cannot move - the tube then has nowhere to go but to follow the radius of the bender
By the looks of that the tube is pulling through the fixed handle of the bender
Edited by Swarbs, 09 July 2014 - 02:43 PM.
