Removing alternator pulley
20 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 July 2014 - 10:05 PM
Hi guys, got this old but new alt which has a stained pulley. How do I go about removing it so I can get it re-plated? I have put it in vice and restricted pulley from turning but now the nut and shaft turn? Thanks. Martyvaruzuma.jpg
#2 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 09 July 2014 - 10:20 PM
Hit it with some penetrene.
You will probably now have to pull it apart.
Remove the rear bearing. Clamp the shaft and try again.
Do not try to stop it turning by clamping the rotor.
You will cause irreversible damage doing that.
#3 Potta
Posted 09 July 2014 - 10:21 PM
Probably need to take the rear cover off, pull out the central shaft and secure it somehow.
#4 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 09 July 2014 - 10:28 PM
Hi
If you have access to a rattle gun - use that. No need to clamp anything.
Bazza
#5 71xu1
71xu1
    Dave
  • 1,275 posts
  • Car:LC GTR XU1
Posted 10 July 2014 - 11:09 AM
+1^
#6 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 10 July 2014 - 11:43 AM
Doubt a rattle gun will do much good.
The shaft will still spin.
#7 _Muzzy_
_Muzzy_
Posted 10 July 2014 - 03:40 PM
Rattle gun will work, at high pressure, please not don't use high pressure to re tension or you will strip
#8 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 10 July 2014 - 04:21 PM
Absolutely - I have done this many times and I understand that this is how it is done in the industry. Hand tighten though.
Bazza
#9 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 July 2014 - 04:41 PM
#10 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 10 July 2014 - 06:17 PM
Surprised me. Thought a rattle gun had to have pressure to rattle against. Not something free spinning.
#11 _hutch_
_hutch_
Posted 10 July 2014 - 06:26 PM
Ive literaly taken thousands of pullies off using a rattle gun
#12 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 10 July 2014 - 09:45 PM
We're all learning here Rob, I did apply a little pressure from my boot to the fan while rattlin'
#13 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 10 July 2014 - 11:03 PM
Knew there had to be some resistance somewhere.
Makes more sense now.
#14 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 10 July 2014 - 11:49 PM
Hi
Nope - no resistance needed. It's called an "impact wrench" for a reason. It's all in the physics of inertia.
Bazza
#15 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 10 July 2014 - 11:53 PM
Will give it a go tomorrow.
#16 Potta
Posted 11 July 2014 - 12:29 AM
haha won't believe it till ya see it hey?
#17 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 11 July 2014 - 09:57 AM
Nope.
Seeing is believing.
#18 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 11 July 2014 - 11:32 AM
Didnt work without some resistance.
Straight on it just spun the alternator.
Didnt take much to get it off though.
Just a screwdriver in the blades.
May be my cheap rattle gun though.
#19 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 11 July 2014 - 05:43 PM
Next Question. How do you tighten it by hand without the shaft spinning?
#20 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 11 July 2014 - 05:46 PM
i just rattle them back on too. probably not the best way, but havent had a prob yet
#21 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 11 July 2014 - 05:56 PM
just did one yesterday arvo, for my brothers boat anchor 253 commodore, the gilmer belt ate the first alternator, this second alternator failure happened when one of the long screw that hold the two halves together came out introduced itself to the alternator fan(the white alternator is the busted one)
C49B04A3-BA34-43AC-9ABB-8499E4D5323F_zps
