Clutch judder
28 replies to this topic
#1 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 26 July 2014 - 07:43 AM
My LX seems to be plagued with clutch judder, I had it with the M21 and now with the Supra 5 speed.
Just wondering if it's just bad luck or could my driving style or even components I chose be somehow causing it?
I recall after putting in a 2.78 diff I had great issues taking off and it would judder like crazy when taking off, when I put a 3.55 in I found out the 2.78 was an EH style diff with different uni, they mechanic was surprised how that lasted as long as it did. I replaced the clutch at the same time.  I had a heavy duty clutch put in that resulted in snapped cables and upon putting in the Supra box they found the fork was also bent.
It's probably done 30,000 km on this clutch and I'm wondering if that's a bit early to be experiencing judder, it only happens on take off, the pedal now bites really low, there's very slight movement off the floor for it to engage and I find myself having to rev it higher to get it to engage smoother.
I currently have it in a workshop and they're checking it out, will have to see what the issue is this time.
s
#2 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 26 July 2014 - 07:01 PM
What type of compound is the clutch plate?
Should last longer than that..they should wear down to the rivets.
Even an uneven tune can cause a similar problem in some cases.
#3 Rockoz
Rockoz
  • 4,009 posts
  • Name:Rob
Posted 26 July 2014 - 09:04 PM
Pressure plate?
#4 warrenm
warrenm
  • 2,115 posts
  • Car:1972 LJ Torana
Posted 27 July 2014 - 08:25 AM
Oil on the friction surfaces, riding the clutch to much, crook engine or trans mounts or as already mentioned pressure plate can cause "clutch shudder". If you've busted a couple of cables & bent a fork, the clutch is to heavy for the set up. Talk someone that specialises in clutches, they can adjust the pressure plate to suit your application, not just take one of the shelf. I've had good results from Western Clutches at St Marys. http://westernclutch.com.au/
#5 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 July 2014 - 02:26 PM
Thanks, my car is currently at Diff Technics and Con gets his clutches from Western Clutch.
I had the bent fork on the previous m21 set up, from memory, I think they may even have used the same pressure plate when the Supra was put in; if possible?
I was thinking of this kit from Sunbury Brakes.
http://www.sunburybr....au/prod185.htm
Any thoughts?
s
#6 N/A-PWR
  • 9,632 posts
Posted 27 July 2014 - 02:35 PM
Hello Stephen,
The 2.78 Diff makes the Clutch work harder,
so if you are still using the same clutch as before,
it is more than likely being the old habit wear and tear.
Hope the New Clutch works well for you.
#7 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 July 2014 - 02:42 PM
Hello Stephen,
Thanks, that explains it, that old clutch must've been on it's way out before I put in that diff.
s
#8 N/A-PWR
  • 9,632 posts
Posted 27 July 2014 - 02:47 PM
 Thank's Stephen,
Another thing comes to Mind,
is that a V8 Clutch is much Bigger than the Little 6 one,
so the clutch is under even more strain,
now the 1 Tonner Clutch is bigger for the 6 cyl,
not sure if that helps, but size does matter.
s
#9 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 July 2014 - 02:51 PM
I had a 253 when I had the M21, I now have a 308.
s
#10 N/A-PWR
  • 9,632 posts
Posted 27 July 2014 - 03:04 PM
Excellent,
I would imagine the 6 spring Clutch Plate be the go:-
http://www.ebay.com....sd=131033184540
#11 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 July 2014 - 03:07 PM
Excellent,
I have a Supra 5 speed gearbox.
s
#12 N/A-PWR
  • 9,632 posts
Posted 27 July 2014 - 03:14 PM
Oh, hmm,
http://www.aussiev8....h-problems.html
#13 _LS1 Taxi_
_LS1 Taxi_
Posted 27 July 2014 - 03:29 PM
I've used a sunbury brakes clutch on a 308 supra box combo. Worked well
#14 N/A-PWR
  • 9,632 posts
Posted 27 July 2014 - 03:39 PM
So this is it Daz hey,
$(KGrHqIOKo0FHYBhqvCVBR4lE4,iHg~~60_12.J
http://www.ebay.com....101787646&rt=nc
Great work Mate.
#15 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 July 2014 - 03:55 PM
The Sunbury one is significantly cheaper; also on ebay.
http://www.ebay.com....196911004&rt=nc
If the picture is correct the Sunbury one has a 4 spring clutch, no spigot bush either.
s
Edited by StephenSLR, 27 July 2014 - 03:55 PM.
#16 N/A-PWR
  • 9,632 posts
Posted 27 July 2014 - 04:02 PM
So will that one be OK Stephen
would the six spring be better than a four spring?
cause, the Hilux would have an easier diff ratio one would think
#17 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 July 2014 - 04:17 PM
No idea, I'll have to see what Western Clutch are offering, price, etc. and weigh it all up.  Con at Diff Technics said to wait until he sees what's wrong with it, my guess is I need a new kit, it'll be great news if I don't.
s
#18 N/A-PWR
  • 9,632 posts
Posted 27 July 2014 - 04:18 PM
OK Cool
#19 _LS1 Taxi_
_LS1 Taxi_
Posted 27 July 2014 - 04:23 PM
Attached File  IMG_2700.JPG   159.53K   1 downloads
The Sunbury clutch kits are painted bright green.
This was also a 6 springer.
If you look close you can see it through the fingers.
#20 N/A-PWR
  • 9,632 posts
Posted 27 July 2014 - 04:25 PM
Very Very Nice Daz
#21 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 27 July 2014 - 05:38 PM
Would be great if you had a Barbados Green Torana, not that anyone would ever see it; but you would know it's there. lol.
s
#22 Rockoz
Rockoz
  • 4,009 posts
  • Name:Rob
Posted 28 July 2014 - 11:36 AM
Old mechanic mate of mine told me years ago.
If you pull the gearbox out always replace the clutch and pressure plate.
Whether it needs it or not.
Saves pulling it out again later to do it.
#23 N/A-PWR
  • 9,632 posts
Posted 28 July 2014 - 11:57 AM
We hear you Rob,
I put a new clutch and pressure plate in on the Engine change 4 months ago in my WB Tonner,
while we were there already, easy as hey.
New spigot bush too
#24 Rockoz
Rockoz
  • 4,009 posts
  • Name:Rob
Posted 28 July 2014 - 12:37 PM
Never worried too much about the spigot.
But thrust bearing as well
#25 N/A-PWR
  • 9,632 posts
Posted 28 July 2014 - 12:46 PM
So true
