![Photo](https://secure.gravatar.com/avatar/edf149548b39c767a234a57de3c03352?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
Frontends
Posted 05 August 2014 - 02:32 PM
Some advice would be great
Thanx
_LC870_
Posted 05 August 2014 - 02:37 PM
Yes it sure is .
Reinforced lower control / suspension arms .
The K frame has got 2 sets of holes for locating the lower control arms .
The lower set of holes were used and these holes were stamped out at the factory and not drilled.
Hope this helps.
Regards LC870
_oz772_
Posted 05 August 2014 - 03:10 PM
![;)](https://www.gmh-torana.com.au/forums/public/style_emoticons/default/wink.png)
Edited by oz772, 05 August 2014 - 03:11 PM.
_judgelj_
Posted 05 August 2014 - 03:28 PM
Brake caliper spacers on the control arms too
_LC870_
Posted 05 August 2014 - 03:46 PM
Aren't the additional set of holes there to lower the upper control arms.......??
Yes that,s right thank you for picking that up
Posted 05 August 2014 - 03:49 PM
No caliper mounting spacers on the stub axles. Only spacers fitted between the caliper halves to suit the thicker discs.
_judgelj_
Posted 05 August 2014 - 03:56 PM
Posted 05 August 2014 - 03:59 PM
Are you sure they are not stub axle spacers?
Yes they are caliper stub axle spacers but XU1's never had them.
_judgelj_
Posted 05 August 2014 - 05:13 PM
Didnt the xu1's run wider discs and use a spacer as standard?
_oz772_
Posted 05 August 2014 - 05:31 PM
_judgelj_
Posted 05 August 2014 - 05:33 PM
So what garbage are the sellers on ebay spinning regarding their use?
Posted 05 August 2014 - 05:49 PM
Question,
Isn't the lower hole sets in the XU1 'K' Frame,
be in the same position as the Standard LC/LJ 'K' frames.
so the Top holes for adjustment brings the top of the wheels in closer.
Posted 05 August 2014 - 06:22 PM
If my memory serves me correctly those stub axle to caliper spacers were used on the HK GTS.
Question,
No, the upper holes in the XU1 crossmember tower are same as S, SL & GTR. The lower holes are XU1 only.
Edited by S pack, 05 August 2014 - 06:24 PM.
Posted 05 August 2014 - 07:10 PM
Holden caliper spacer , ie stub axle spacer P/N is 2811049 .
You WON'T find this number listed in any of the LC/LJ parts catalogues .
You WILL find this number listed in the HT/HG parts catalogues because HT 350 GTS AND ALL HG disc brake vehicles regardless of engine displacement had increased thickness disc rotors that required the use of the 2811049 spacer .
There is no part number listed for the spacer that goes between the caliper halves of XU1's and the above vehicles .
Anyone wanting them before reproductions became available had to buy new complete calipers from Holden or get used calipers .
Posted 05 August 2014 - 07:28 PM
Great Thank's Dave,
Just thought the space above the Standard 'K' Frame holes, were for the XU1.
So looked around and found this link from Marty's Thread:-
http://www.gmh-toran...e-2#entry597470
Edited by GASPOWER, 05 August 2014 - 07:29 PM.
_judgelj_
Posted 05 August 2014 - 10:44 PM
So when ebay sellers describe them as being caliper to stub spacers, do they mean caliper halves?
Posted 05 August 2014 - 11:19 PM
No. Caliper to stub spacers fit where the caliper bolts onto the stub axle.
_judgelj_
Posted 06 August 2014 - 12:40 AM
I know, but what im referring to is this:
These are a new pair of brake caliper to stub axle spacers, to suit the wider disc used on Torana XU1 and GTR ran these caliper spacers as standard, in addition to other applications.
For those of you who haven’t been able to work out why you can’t fit your brake pads into the caliper, this missing spacer may be your problem. Most were thrown away or lost years ago, that’s why we reproduced them from an original spacer. These have been made in zinc seal antirust coated steel as the originals were very prone to bad rust.
You can sometimes find second hand pairs, but these are for people who prefer a nice new rust free pair, ready to use.
_oz772_
Posted 06 August 2014 - 06:07 AM
These are a new pair of brake caliper to stub axle spacers, to suit the wider disc used on Torana XU1 and GTR ran these caliper spacers as standard, in addition to other applications.For those of you who haven’t been able to work out why you can’t fit your brake pads into the caliper, this missing spacer may be your problem. Most were thrown away or lost years ago, that’s why we reproduced them from an original spacer. These have been made in zinc seal antirust coated steel as the originals were very prone to bad rust.
The caliper spacers look like this (you'll find a good photo in Torana Tough as well if you have that, in the LC XU1 section).
Posted 06 August 2014 - 09:52 AM
Obviously the twits selling these (not applicable to Torana XU1 and most definitely not GTR) caliper to stub axle spacers haven't got a clue.
#21
_LONA-CK_
Posted 06 August 2014 - 03:02 PM
Just wondering if a lj xu1 front end is different to a standard front end and if so what is the difference,
Thanx
hi mate are you talking bare k frame or complete front end???
cheers gong
#22
Posted 06 August 2014 - 04:44 PM
#23
_LONA-CK_
Posted 07 August 2014 - 07:45 AM
ok i think the fellers above have covered most of what you need to know
from the start of the CK XU1 in 1971 all xu1 front ends where the same apart from,,, bolts/nuts/springs and date codes, some had more wheel spacers then others
they all had caliper spacers to suit the thicker discs
they all had the 2 sets of holes even the 1970 model had these
all XU1S from the start of the CK XU1 had the reinforcement around the bottom ball joints
the thing that none of the xu1s had was these plate that are found on all other disc brake models
the other changers were brackets from year to year and code color blobs that can be seen in this pic.
here is a pic of the brackets on a 1970 lc xu1 mock up front end
i hope i and we have helped you.
cheers gong
Edited by LONA-CK, 07 August 2014 - 07:52 AM.
#24
_judgelj_
Posted 07 August 2014 - 09:58 AM
So do the two sets of holes only appear on xu1 k frames?
#25
_oz772_
Posted 07 August 2014 - 12:59 PM
This has to be a sticky!!
Yes
