Posted 26 August 2014 - 12:13 PM
Posted 26 August 2014 - 12:21 PM
Posted 26 August 2014 - 01:20 PM
Posted 26 August 2014 - 02:46 PM
Posted 26 August 2014 - 03:01 PM
Very Good Work Marty,
You shouldn't have to do anything extra,
if the Heaterbox is a replacement part hey.
I like your steel putty idea.
Posted 02 September 2014 - 02:42 PM
Posted 04 September 2014 - 09:11 AM
Hi Nathan, you're probably right!
I did this twice so when I pulled it apart I noted how much had squished in and made note and used less and kept it closer to outside edge.
Once this product is in I think it will perform its job without any issue. Even if the excess did drop off inside I can't see it being an issue.
Marty
Posted 13 June 2022 - 07:20 AM
Hi All , my heater box is out at the moment and having an issue with the short link controlling the fresh air inlet flap door.
Looking inside the top cover, when operating the mechanism by hand, it seems like the short link wont push to open the door, like the Tab that is on the fresh air flap, is under-centre of the pivoting shaft, so effectively its jamming, and the link beds under pressure.
By giving the flap a slight push with my finger, overcomes the under-centre pivoting issue.
The Operating Cam is all lubed up - which i don't have a concern with - its just the above.
From closed, how far should the Fresh air door actually open?
Should its range of motion be from vertical closed - to horizontal at 90 degrees' when fully open , or just partially open/closed?
TIA
Jaso
Posted 13 June 2022 - 05:27 PM
Pretty sure mine had a full range of motion when out of the car. When connected to heater controller I think the range is reduced.
Marty
Posted 13 June 2022 - 07:01 PM
Posted 13 June 2022 - 07:34 PM
Jaso, this may help.
LJ Heater flap rework P1.JPG 148.98K
15 downloads
LJ Heater flap rework P2.JPG 134.18K
22 downloads
LJ Heater flap rework P3.JPG 114.85K
15 downloads
Posted 13 June 2022 - 07:52 PM
Posted 13 June 2022 - 08:14 PM
Posted 08 September 2022 - 08:26 AM
I bought one of the repro heater box's and thought I'd share my experience. Firstly this is a smooth almost grey finish compared to originals that are rough black finish. I plastic primed it then sprayed it 2k black with a matting agent. It wasn't intended but the matting agent gave it a rough finish.
The heater core is wrapped in foam to stop loss of air and rattling.
Used the glazing putty to seal the two sides together.
In the second photo. The panel that the flap hinges off, has a screw/pin? that goes through from the bottom plate and into the hole provided to secure the flap. If anyone knows what it is called, or even better, has a photo of the screw/pin? it would be greatly appreciated. cheers Ian.
Posted 13 September 2022 - 06:57 AM
Posted 19 September 2022 - 09:09 AM
I have been told there is no pin or screw. That hole in the indented bit is what secures the flap support when the base is bolted on. Just thought I would add this in case anyone else is doing there heater box. Thanks Dave for your help with this.
You are welcome Ian.
Posted 22 September 2022 - 08:03 AM
Ian, pic of the direction of rotation of the heater motor for you as promised.
Apologies for the lateness posting this, work has been quite busy.
LC Heater motor.jpg 70.66K
8 downloads
