This may be a silly question but is there any way to shorten the spindle length of a stub axle ? .
I have been trying to find some decent info on the subject but no luck so far .
Posted 02 September 2014 - 05:52 PM
Posted 02 September 2014 - 06:00 PM
you mean where the bearing and seal goes on,
if so, you can have bearing and seal surfaces machined back further Troy.
also the thread for the castellated nut
Posted 02 September 2014 - 06:15 PM
Posted 02 September 2014 - 06:33 PM
P76 disks and a CRS conversion kit will move the hub face in 12mm or so, also move your brakes over by the same amount.
Posted 02 September 2014 - 06:41 PM
I'm looking at trying to fit volvo discs , just looking for ideas first .
rotor hq.jpg 110.62K
2 downloads
Posted 02 September 2014 - 06:45 PM
I see, just the nut side to be shorter.
what about Volvo Stubs?
Posted 02 September 2014 - 06:52 PM
volvos have strut towers i think ? , not stubs
Posted 02 September 2014 - 07:46 PM
1966 Volvo Stub Axle:-
used on trailers these days
Posted 02 September 2014 - 09:00 PM
Posted 02 September 2014 - 09:27 PM
got plenty of torana pattern wheels and want to use a rotor that doesn't need machining ever time it needs replaced .
Posted 02 September 2014 - 09:36 PM
Posted 02 September 2014 - 10:03 PM
narr cant space the inner bearing out anymore , the inner rotor face is already too far away from the caliper mount (30mm compared to the toranas 20mm ) .
I will try and get some more measurements to give you a better look at it .
Posted 02 September 2014 - 10:17 PM
I vaguely recall this being a conversion done to HR frontends in the olden days, so I reckon it can be done.
I have no idea on the method used, unfortunately.
Posted 03 September 2014 - 07:12 AM
Mount the stub axle "between centres" in a lathe, & machine away.
Posted 03 September 2014 - 06:29 PM
I agree with Warren,
Troy, you have enough metal to machine back to suit the Volvo hub.
