New LJ Heater cable
17 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 21 September 2014 - 10:26 PM
Has anyone found a new heater cable option for the hot/cold on the box in engine bay?
This cable is under heaps of pressure when pushing closed. Works fine when pulling but tends to bend wire at the controller under dash when pushed.
Mine was bent so I straightened it and lubricated the wire but it still binds on the push stroke.
I feel to give this system any chance of working the cable and wire must be 100%.
Is there anyone who makes these or can make then better?
Marty
#2 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 26 September 2014 - 05:51 PM
Anyone?
#3 rodomo
  • 18,037 posts
Posted 26 September 2014 - 09:36 PM
http://www.fdrive.com.au/
#4 S pack
  • 15,722 posts
Posted 27 September 2014 - 12:29 AM
The bent cable is only a consequence of the real problem.
#5 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 27 September 2014 - 08:37 AM
That's so right Dave.
My top three reasons are:
Stiff mechanism on top of heater box.
Cable route wrong.
Cable binding in casing.
I think I have cable binding issue plus having been bent before on previous heater box.
Cable feels oxidized and rough and maybe cutting into outer sheath.
#6 shadey1963
shadey1963
  • 343 posts
  • Name:Steve
  • Car:5/72 LJ S 2 door Model
Posted 27 September 2014 - 11:04 AM
One of these might help lubricate the whole cable length internally.
http://www.motorcycl...pro-cable-luber
#7 S pack
  • 15,722 posts
Posted 27 September 2014 - 11:15 AM
Stiff mechanism on top of heater box - most likely cause is stiff operation of components inside heater box.
Cable route wrong - pretty much only one way to route the cable from the control unit to the heater box in engine bay.
Cable binding in casing - possibly
I think I have cable binding issue plus having been bent before on previous heater box - once the cable is bent it will never work properly again.
Cable feels oxidized and rough and maybe cutting into outer sheath - could be grit ingested into the cable and casing.
Pull test in both directions of lever on top of the heater box should not exceed 4.75lb of force to operate the flaps inside the box.
GMH did not resolve this cable bending issue until heater units produced from the 1/11/1973.
Edited by S pack, 27 September 2014 - 11:18 AM.
#8 ls2lxhatch
  • 5,332 posts
Posted 27 September 2014 - 11:26 AM
Has anyone tried putting a spring on the heater box lever to make it easier to push?
Once the cable has been bent it will be easier to bend again. See what fdrive have as Rodmo suggested.
Edited by ls2lxhatch, 27 September 2014 - 11:32 AM.
#9 rodomo
  • 18,037 posts
Posted 27 September 2014 - 02:05 PM
They will make just about any cable to suit your needs.
Having said that, a smart bloke could probably make that pretty easily using an after market choke or bonnet cable?
http://www.ebay.com....=item1c3533c57e
#10 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 08 October 2014 - 10:19 PM
I have a result!
Firstly made a jig to give me correct length and diameter or curled wire ends. Used timber with fixings for curling wire around.
Got some wire from a lawn mower shop, it's 1.4mm compared to original 1.15mm but still slides freely through original casing.
Curled it around pins.
Fitted and tested and I think it's a winner. Should be stronger too.
So keep those old broken casings cause they can be saved.
Marty
#11 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 09 October 2014 - 06:30 AM
Well done, good result.
#12 MustardGTR
MustardGTR
  • 243 posts
  • Car:72 GTR, 73 GTR
Posted 09 October 2014 - 10:34 AM
As always an excellent result Marty.
What might seem like a small change in wire diameter now represents a set-up 220% stronger in bending (ceteris paribus).
What was GMH's solution beyond 1/11/1973?
#13 S pack
  • 15,722 posts
Posted 09 October 2014 - 04:27 PM
They modified this part.
#14 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 October 2014 - 06:01 PM
Wow! I did a mod to that piece without even realising it was a factory change in late 73.
#15 S pack
  • 15,722 posts
Posted 09 October 2014 - 07:09 PM
Yes you did Marty, however you did go a tad further than GMH did :)
#16 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 09 October 2014 - 09:38 PM
Hi Aleks, not sure how you worked out that percentage and where those big words come from.
But Yeah! it feels a lot stronger.
#17 _ljmaz_
_ljmaz_
Posted 12 April 2015 - 11:02 AM
Was about to buy a 2nd hand heater cable when i found this post.
Will hopefully have the same successful result.
Love this forum - so helpful!
Thanks guys!
ljmaz
#18 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 18 April 2015 - 10:37 PM
Hi Mario,
This has been very successful for me so far.
Well worth doing. :-)
Marty
