Booster to tip of pushrod is set to 8.280mm as mentioned in manual.
Piston hole depth in master is approx 40mm. This section sits in booster by about 20mm. Therefore there is a gap of about 20mm from rod tip to piston. This doesn't make sense? So when pedal is pushed nothing happens for 20mm?
I think it's done as the manual but it doesn't seem logical.
Am I missing something?
Marty
