I presume it looks something like this? This has a earth contact so I presume it's not correct because it fits into plastic.
Marty
Posted 03 October 2014 - 04:41 PM
Posted 03 October 2014 - 05:31 PM
Marty
Basically the same as this one but has a wire connector the same as used for the blue wire instead of the earth tab .
Edited by S pack, 03 October 2014 - 05:33 PM.
Posted 03 October 2014 - 06:01 PM
Drill a small hole in the plastic and solder a wire to the earth tab if you cant find the right one.
Posted 04 October 2014 - 03:25 PM
Posted 04 October 2014 - 04:31 PM
Marty, see the 2nd pic in post #8. For the brake warning light there would be one pink wire (+12v) instead of the green wire and two tan wires (h/brake & brake fail switch) instead of the two black wires shown on the bulb holder the pic.
http://www.gmh-toran...sh/#entry848517
Posted 20 October 2014 - 09:16 PM
Posted 20 October 2014 - 09:23 PM
Help! Can I get confirmation on which light is where on a 73.
Top brake light, is it handbrake or low fluid warning.
Marty
Marty it's both handbrake warning light and brake fail light in one. Same as the brake light in the lower position on the 72's just moved up to the higher more visible position for 1973. The redundant lower warning light aperture on the 73 fascia is blanked off with a piece of black vinyl coated metal.
Edited by S pack, 20 October 2014 - 09:26 PM.
Posted 20 October 2014 - 09:35 PM
Posted 20 October 2014 - 09:38 PM
You are most welcome mate.
Posted 20 October 2014 - 09:40 PM
This is kind of random, but I owe Marty a schooner as a result of this thread.
I just strolled out to the shed to see if I had one of these funny looking globe holders in a harness that I recently pulled out of a HG sedan.
I didn't....
But when I walked into the shed there was a strong stench of petrol.
The Truckster had sprung a leak next to a hose clamp and had a nice pool of 97 underneath it.
All fixed now.
This joint is useful in all kinds of ways. Beer for you next time I see you, mate.
Posted 20 October 2014 - 10:01 PM
Posted 20 October 2014 - 10:06 PM
I can do that.
Hes closer, too.
Save me an airfare.
Posted 20 October 2014 - 10:09 PM
Just email it to me Craig.
