intermittent wiper
#1 _Chamois hatch_
Posted 18 July 2006 - 08:48 PM
Posted 18 July 2006 - 08:53 PM
#3 _Chamois hatch_
Posted 18 July 2006 - 09:09 PM
Edited by Chamois hatch, 18 July 2006 - 09:15 PM.
#4 _sstorana_
Posted 18 July 2006 - 09:12 PM
get hold of the setup out of a UC Torana. It will connect straight up and if you don't have a choke you can use that hole for variable switch..
Mick
Edited by sstorana, 18 July 2006 - 09:13 PM.
Posted 18 July 2006 - 09:13 PM
#6 _Chamois hatch_
Posted 18 July 2006 - 09:19 PM
john
Posted 18 July 2006 - 09:20 PM
#8 _Chamois hatch_
Posted 18 July 2006 - 09:44 PM
john
Posted 19 July 2006 - 10:33 AM
All it needs to fit a UC style one is to connect its earth, power to fusebox (yellow wire, I think), mount the on off and sweep time control knob, and cut the white wire from the existing windscreen wiper switch to the motor, and splice in the two white wires from the UC intermittent unit. Make sure you tag which white wire is which (ie one goes to switch, and one to windscreen wiper motor) on the UC unit before you pull it out, otherwise it will not work. If ti doesn't work, try swapping the white wires around.
When the intermittent wiper switch knob is in the off position, the wipers work as per normal via the original switch. Leaving the wiper switch off, and turning on the intermittent wiper switch activates the wipers intermittently.
Good idea to mount the control switch in the choke hole - I hadn't thought of that.
Posted 19 July 2006 - 11:56 AM
#11 _lx5008_
Posted 19 July 2006 - 12:25 PM
Posted 19 July 2006 - 02:46 PM
Get me one while you are there.
If you change to a UC stalk, then the intermittent switch goes where the old wiper switch went.
Grant..
Posted 19 July 2006 - 04:46 PM
#14 _Chamois hatch_
Posted 19 July 2006 - 04:55 PM
thanks for all the advise.
#15 _Yella SLuR_
Posted 19 July 2006 - 05:20 PM
Posted 19 July 2006 - 07:12 PM
There are also kits you can get that do this.. I had one installed in my torry many moons ago.. Was an addidtional knob though and looked pretty poor!
I think the UC one is the way to go! Why werent you guys around when i was doing up my torry!
Posted 19 July 2006 - 07:13 PM
I just used the dash mounted switch and fitted it in the choke hole. I didn't want to mod the car too much. It's the best setup to use as it's a variable speed setup. I drew up this rough wiring diagram at the time, which shows how to wire the HZ-UC system into the LX with minimal fuss. I hope it's of some use.RED, did you convert to the stalk on the column or keep the dash mounted wiper switch and just added another switch for the intermittent� part of things?
john
Edited by REDA9X, 19 July 2006 - 07:24 PM.
#18 _kaz from adelaide_
Posted 19 July 2006 - 07:29 PM
Edited by kaz from adelaide, 19 July 2006 - 07:30 PM.
Posted 19 July 2006 - 07:51 PM
Posted 19 July 2006 - 08:04 PM
#21 _lx5008_
Posted 19 July 2006 - 08:11 PM
#22 _kaz from adelaide_
Posted 19 July 2006 - 08:31 PM
#23 _devilsadvocate_
Posted 19 July 2006 - 09:24 PM
Edited by devilsadvocate, 19 July 2006 - 09:26 PM.
#24 _EXLXSL_
Posted 20 July 2006 - 07:54 PM
Wipe time is variable between 2 and 20 times per minute and the auto stop/park switch in the wiper motor has to be working.
#25 _Chamois hatch_
Posted 20 July 2006 - 08:43 PM
john
