Headlight adjustment
How to set headlights measure
14 replies to this topic
#1 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 13 December 2014 - 10:21 AM
Hi Guys,
does anyone know the measurements for setting headlights?
I'm after distance from wall and what heights etc.
Ideally I can only get about 1.5 mtrs from wall on level ground.
I have searched, but come up with zilch
Marty
#2 N/A-PWR
  • 9,637 posts
Posted 13 December 2014 - 10:41 AM
Hello Marty,
I remember the 600mm wall height measurement that the Transport Inspector said, but was 30 years ago.
Also, the CS10 WRX I had, where I checked the low beam headlights shining on a wall 4 metres away,
showed the drivers side light beam was 50mm lower than the other, possibly for the oncoming traffic vision.
Hi Guys,
Marty
- 600mm maximum light height
Edit:-
Do the opposite to this Marty.
Edited by NA-PWR, 13 December 2014 - 10:53 AM.
#3 N/A-PWR
  • 9,637 posts
Posted 13 December 2014 - 10:58 AM
and Our Forum Topic's as well:-
https://www.google.c...ferrer:source?}
and other:-
https://www.google.c...C_en&gws_rd=ssl
Edit:-
http://www.gmh-toran...hts/#entry77107
So all this appears to say the headlight light will be below the bonnet height and just to the left in Australia's case.
Edited by NA-PWR, 13 December 2014 - 11:08 AM.
#4 _Macca97_
_Macca97_
Posted 13 December 2014 - 01:19 PM
someone around, mostlikely a mechanic that does rego's should have a headlight aimer, i no in NSW its law to have one if you do pinkslips, not sure about WA, ill have a look for the wall measurements for you aswell marty :)
#5 Ice
  • 15,200 posts
Posted 13 December 2014 - 02:42 PM
600 mm of the ground to the centre of headlight Marty
#6 _hutch_
_hutch_
Posted 13 December 2014 - 02:51 PM
I just use a wall,measure up to the centre of the headlight,run a line of black tape at that height on the wall, set the car back about 5 meters and aim them by eye,take it for s drive and you will soon see if their right or not,its not rocket science
#7 rodomo
  • 18,037 posts
Posted 13 December 2014 - 02:52 PM
Drive it up to a wall.
Looking from the side, mark the wall across at the center of the height of the headlamp.
Then, looking from the top, mark the wall up and down at the center of the width of the headlamp.
You should now have a cross on your wall.
Do the same for the other side headlamp.
Back up in a straight line as far as possible (a car length will do though)
On HIGH beam, the middle of your beam should hit the crosses.
On low beam, the middle of your beam should dip to the left.
Hutch has summed it up.................I'm too slow DAMMIT!
Edited by rodomo, 13 December 2014 - 02:53 PM.
#8 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 13 December 2014 - 04:11 PM
Cheers guys, wall marked out and in the process of doing them.
#9 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 13 December 2014 - 04:28 PM
I remember hassling one of my mates years ago because he must've been looking for possums in the trees they were aimed so high, the fact that he had an auto ford didn't help him either.
I know this doesn't help you Marty but it's good to laugh at things.
#10 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 13 December 2014 - 04:39 PM
Or you could try this method,the standard distance seems to be 25ft.
http://legacygt.com/...21f9197800&
#11 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 13 December 2014 - 04:57 PM
That is for America of course,just reverse the hot spots for our side of the road in regards to the beam spots.
Cover the  light not being adjusted when making adjustments,or just pull the plug on the light not being adjusted.
#12 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 13 December 2014 - 05:14 PM
#13 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 13 December 2014 - 05:47 PM
Don't know if this will help, it's out of Max Ellery's Repair Manual.
Attached File  Headlight alignment diagram.jpg   62.85K   10 downloads
Edited by Mort, 13 December 2014 - 05:56 PM.
#14 N/A-PWR
  • 9,637 posts
Posted 13 December 2014 - 05:51 PM
Great Help Mort  :spoton:
#15 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 13 December 2014 - 06:01 PM
Was too slow to add this one and change from PDF file to JPG so you can see it without downloading it.
HeadlightAlignmentInstructions_zps89a924
