tail shaft loop
14 replies to this topic
#1 _benster208_
_benster208_
Posted 06 April 2015 - 05:43 PM
I have bought a tailshaft loop off ebay and it appears way too big to fit under the torana . I was wondering if anyone could put up some pictures showing the best spot to fit a tailshaft loop. I'm pretty resigned to cutting the mounts down to fit but i'd like some ideas first please.
#2 76lxhatch
  • 7,202 posts
Posted 06 April 2015 - 08:26 PM
There's some extra pieces hanging off mine but hopefully you can still see something here:
Immediately in front of the seat mounting plate is a good spot, the floor is flat and it will sit against it nicely. But yes, you will have to cut a universal loop down to size. Cut the ends off the outriggers as they are far too long, and use them for the doubler plates on the inside. Also cut the two halves of the loop part a little shorter and tweak to fit nicely.
#3 _benster208_
_benster208_
Posted 07 April 2015 - 08:25 PM
this picture is just what i'm looking for.  I didn't realise that I would need to trim down the loop itself.
#4 76lxhatch
  • 7,202 posts
Posted 08 April 2015 - 05:50 AM
Yeah the tunnel isn't tall enough and you don't want the bottom half hanging down too low either.
I've since fitted one to the rear half of the driveshaft, that was even more fun!
#5 _LHSL308_
_LHSL308_
Posted 08 April 2015 - 01:47 PM
I've got a brand new tailshaft loop I'm going to offload for $30 pickup if anyone's interested. Bought it for my Torana but that is now gone. PM me if interested.
#6 hainzy
hainzy
  • 502 posts
Posted 08 April 2015 - 03:11 PM
Gday mate. Ill take it if no one else has claimed it. Ill PM ya. Cheers.
#7 _LHSL308_
_LHSL308_
Posted 08 April 2015 - 05:34 PM
Pm sent mate.
#8 _benster208_
_benster208_
Posted 04 June 2015 - 07:17 PM
20150517_170536_zpsaxhobtuy.jpg This is the final item after I cut it down
#9 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 04 June 2015 - 07:20 PM
(Looks for other half)
#10 _benster208_
_benster208_
Posted 04 June 2015 - 07:25 PM
I couldn't see why I needed the top half . If the shaft lets go it won't be able to go far and the bottom half will do its job which is to stop the shaft hitting the ground.
#11 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 04 June 2015 - 07:27 PM
Also to stop it punching a hole in the floor.
#12 _benster208_
_benster208_
Posted 04 June 2015 - 08:43 PM
I can't see how it could punch a hole in the floor. and If it could I still couldn't see how the loop would stop it.  139_zpselo2jneg.jpg
#13 76lxhatch
  • 7,202 posts
Posted 04 June 2015 - 08:55 PM
Worst case scenario it certainly can go through the floor. If you're installing it to comply with any type of rule it will need to be 360 degree regardless anyway.
#14 LXCHEV
LXCHEV
  • 3,551 posts
  • Car:'76 LX - 383 Chev
Posted 04 June 2015 - 09:34 PM
Yep "360 degree" tailshaft loop is standard requirement in the rule book for any sort of driving event.
#15 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,671 posts
  • Car:LJ GTR
Posted 04 June 2015 - 10:17 PM
The reason why it can easily punch a gape'n big hole through the floorpan is because the tailshaft is bolted to read end that's still spinning it faster than wheels are turning, So when the front uni lets go the front end of shaft starts to whip around, Thankfully with the "Loop" it can't go up or down, but without the top piece in place will make one hell of a noise right before punching through the tailshaft tunnel and into your cabin, It's at this time you'll soil your pants and won't be able to stop or pull over fast enough......
