Does anyone have dimensions for the lj brake / clutch pedal bushes. I believe that the bushes are different for the two pedals.
Posted 01 May 2015 - 07:00 PM
_hutch_
Posted 01 May 2015 - 07:22 PM
Posted 01 May 2015 - 07:27 PM
Posted 01 May 2015 - 07:51 PM
I used Rares as well and OK, I thought they were a Falcon part so are diff to original
Posted 01 May 2015 - 08:41 PM
LC/LJ 6cyl clutch pedal bushes are different to the bushes used on the brake pedal shaft.
Posted 02 May 2015 - 01:00 AM
Used rares parts on mine vaguely remember used same for both pedals.
Those thin cruddy plastic things?
Posted 02 May 2015 - 07:53 AM
I beg to differ Dave.
They run on a common shaft.
I could be wrong because I modified my setup.
But I doubt it. :-)
Marty
Posted 02 May 2015 - 08:21 AM
But I doubt it. :-)
Marty
Marty, you can email me a 6 pack of Great Northern.
http://www.gmh-toran...pedal-bearings/
Dave.
Posted 02 May 2015 - 06:00 PM
Just been down the bottle shop Dave.
Here's your emailed 6 pack mate.
Unknown.jpeg 4.82K
2 downloads
Posted 02 May 2015 - 06:09 PM
You little ripper Marty
My email is a bit slow lately but they should come through soon, I hope!
Dave.
Posted 02 May 2015 - 07:45 PM
I appreciate all the input but some say the bushes are the same whilst others say they are different ???? My original enquiry was for dimensions so that I can buy brass or phosphor bronze bushes.
Posted 02 May 2015 - 07:57 PM
Hi Ray
I posted this link because I thought it would answer most of your question. http://www.gmh-toran...pedal-bearings/
Kockum's info in that thread is 100% correct, the the clutch pedal bearings are a different part to the brake pedal shaft bushes.
Best way is to take your clutch and brake pedals to your local bearing shop and they will measure them up and supply what you need.
Dave.
Posted 04 May 2015 - 06:32 PM
Thanks Marty.
They came through yesterday but I'll need to have the 3D printer recalibrated.
As you can see they came out a little blurred. Nice and cold though and taste fantastic.
Dave.
Posted 04 May 2015 - 07:33 PM
LOL^
_grumpy 026_
Posted 05 May 2015 - 07:17 AM
It would be helpful to know what the replacement bush for the clutch pedal is so I can order some, the closest place to me is in the ACT, a two and a half hour drive away.
G.
Posted 05 May 2015 - 07:53 AM
Guy's
G.
There is no direct replacement/repro for the original type clutch pedal bearings that I know of.
Edited by S pack, 05 May 2015 - 07:53 AM.
_mikecatts_
Posted 05 May 2015 - 11:08 AM
looking at the rares site.. they have a ford pedal kit with what looks to be the bit in there. dont know if its the right size.. but seems they are available, just have to track down.. Ive tried this site, dont really know what us model of car it will come off.
http://www.jegs.com/...dal Bushing Kit
found these... asking measurements now.. look to be the part.. "bedford" bit
Edited by mikecatts, 05 May 2015 - 11:22 AM.
_grumpy 026_
Posted 05 May 2015 - 01:10 PM
Those Jegg"s Bushes look the same as Rares, brake pedal shaft bushes.
It's the clutch bushes I would like to be able to order and get hold of.
G.
_mikecatts_
Posted 05 May 2015 - 02:17 PM
_les_
Posted 05 May 2015 - 05:34 PM
Les
#21
Posted 05 May 2015 - 06:36 PM
The easiest way to see if they are different size between clutch/brake would be just measure the bolt/s/pin or whatever they use and the holes in pedal boss and compare,on the LH/X they are a very thin material...strong as buggery despite the thin wall with the right lubrication...dry lube molybdenite is a pretty good product?
#22
_les_
Posted 05 May 2015 - 09:58 PM
OFFER TAKEN UPIf anyone wants to try the Ford bush let me know and I will send you one free of charge.
Les
#23
_mikecatts_
Posted 07 May 2015 - 06:04 AM
i measured mine.. 18.6 outer x 16 mm inner.... there are 2 per pedal...
#24
_grumpy 026_
Posted 07 May 2015 - 07:30 AM
I found the Rares listing and know the part numbers so that I can order some from them to try, but will wait to see if the post above shows if they fit.
G.
#25
Posted 07 May 2015 - 07:34 AM
Thanks Mike, same for brake + clutch ?
