Need help checking these tag's
16 replies to this topic
#1 _toranaheath_
_toranaheath_
Posted 22 October 2015 - 12:36 PM
Hey guys, could someone please shed some light on the info i have on this car.
Apparently a 253 SLR.
Model: LH8VD69
Body: 439366M
Trim: 1878-66V
Paint: 568-15893
Tag states L32 (253), M40 & GU7
Skinny vin tag: 8D69RDJ4393660
I havn't confirmed if the chassis number matches the plate yet, but just wanted to check that these tags belong to an L32 SLR
Thanks in advance guys
#2 S pack
  • 15,726 posts
Posted 22 October 2015 - 12:57 PM
Model: LH8VD69
Body: 439366M
Trim: 1878-66V
Paint: 568-15893
Yes, 253 Trimatic SL/R
#3 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 22 October 2015 - 12:59 PM
Tags could be off anything if the chassis no. doesn't match, first thing I'd check...
#4 _toranaheath_
_toranaheath_
Posted 22 October 2015 - 01:03 PM
Yes i will be confirming the chassis number next to confirm it all matches up!
#5 hanra
  • 10,975 posts
Posted 22 October 2015 - 01:41 PM
Chassis number will only match the ADR plate.
#6 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 23 October 2015 - 07:33 AM
True.
From the body number you may be able to get a range of chassis numbers or dates where it should fall within; others here with LH's may be able to help.
Would Holden would have records if you gave them the VIN?
s
#7 yel327
  • 13,643 posts
Posted 23 October 2015 - 08:09 AM
No. All they'll tell you is that the car was what is on the VIN plate by the PSN and anyone here could tell you that. They may be able to confirm an original engine number but it is only a 4.2L so that isn't as important as the ADR tag matching the chassis number and it being correct for the other tags. Being an auto at that stage I think it should still have ADR9 on the ADR plate so that will help heaps plus it should be 7/74 compliance.
#8 _toranaheath_
_toranaheath_
Posted 24 October 2015 - 11:32 AM
Hey guys. Were having a little trouble reading the chassis number from the body & the adr tag but they both look like:
BLH 051336M
And looks like 09/74' date on adr tag
Does this appear to match up with the above details??
Edited by toranaheath, 24 October 2015 - 11:47 AM.
#9 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 24 October 2015 - 11:38 AM
BLH 051336M
And 09/74 date on adr tag
Some pics would be good; we can check the font to see if either were restamped.
s
#10 hanra
  • 10,975 posts
Posted 24 October 2015 - 12:35 PM
Prob about right for a 9/74. Mine is 10/75 and is 055XXXM
#11 _toranaheath_
_toranaheath_
Posted 24 October 2015 - 01:15 PM
I will get pics soon. Just hard to read chassis number because of the paint covering it. Adr tag is slightly hard to read as it hasn't been cleaned up
#12 Bigfella237
Posted 24 October 2015 - 07:36 PM
VIN: 8D69RD J439366H
Body: 439366M
Chassis: BLH051336M (09/74 date on adr tag)
Something very wrong there, that VIN & body number should belong to roughly a July '74 built LH SLR4200 with a chassis number around ALH013xxxM
BLH051336M should belong to a Sept '75 car
The chassis and body numbers are over a year apart!
Are you sure the compliance plate says 1974? BLH chassis numbers didn't start till 1st January 1975
As Heath said above, we really need (clear) pictures.
Edited by Bigfella237, 24 October 2015 - 07:38 PM.
#13 _toranaheath_
_toranaheath_
Posted 24 October 2015 - 09:24 PM
Im still waiting on better pics of adr tag & chassis number, but chassis is hard to read due to layers of paint as most of you guys would know about.
I might be wrong, its probably 09/75' on the adr tag.
Will get owner to check his rego papers as well
Edited by toranaheath, 24 October 2015 - 09:27 PM.
#14 yel327
  • 13,643 posts
Posted 25 October 2015 - 10:07 AM
Agree with the above. Although Dandenong did get predictive sometimes on the 8-9th month changeover, being a D in the VIN 99.9% of the time will be pre 9/74.
#15 _toranaheath_
_toranaheath_
Posted 25 October 2015 - 05:31 PM
Having issues with seller sending through clear pics...Hmmmm....
#16 Bigfella237
Posted 25 October 2015 - 06:57 PM
LOL... I wonder why
#17 _toranaheath_
_toranaheath_
Posted 25 October 2015 - 08:25 PM
Thanks for the help guys, the car is magically sold now, even though it wasn't even up 4 sale. Beware of these ID tags!!!
